Page 2 of 6 1 2 3 4 5 6
Re: Gen 3 Hemi on dirt.. [Re: autoxcuda] #1304090
09/15/12 03:56 PM
09/15/12 03:56 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
The sanctioning body is AMRA. As of now, no GM LS engines being ran. It is just a matter of time though, I believe. Steel blocks are mandatory.
If you like drag racing, support your local track.
Re: Gen 3 Hemi on dirt.. [Re: CHAPPER] #1304091
09/15/12 04:04 PM
09/15/12 04:04 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
GM parts was experimenting with an LS motor at our track a couple years ago. For a possible higher HP level ZZ4 type crate motor deal.
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
Re: Gen 3 Hemi on dirt.. [Re: autoxcuda] #1304092
09/16/12 01:48 AM
09/16/12 01:48 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
what tranny a falcon, bert,or a glide? that had to be some work and money to set that motor set up for that kinda racing, what rpm you guna turn it
Re: Gen 3 Hemi on dirt.. [Re: Cheatham] #1304093
09/16/12 03:19 AM
09/16/12 03:19 AM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
There is few guys that run the 525 crate LS motor in mods around here. In fact one guy won a few USMTS races and people started crying about the lighter weight. They made him add weight at the mid plate and he still won. He finally put a mod spec motor in and won with that too. After that people quit crying.
Re: Gen 3 Hemi on dirt.. [Re: gtsdude] #1304094
09/16/12 04:07 AM
09/16/12 04:07 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
When we switched to ZZ4 crates years ago same thing happened with us. We were the first to run them. They added weight, we won. Some other racers switched over. But we still won. Then other racers whined that our motor was "special".
So one night after we won, a guy says "I want THAT motor" So we said ok, buy us a new one and you can have THAT one right NOW. So we yanked the motor right after tech and handed it too him.
Soon all the cars coverted to crate motors and were paying $10K less for motors, turned less RPM, and lasted much longer.
Re: Gen 3 Hemi on dirt.. [Re: Cheatham] #1304095
09/16/12 09:43 AM
09/16/12 09:43 AM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
It has a Bert transmission/bellhousing/starter set-up. Also, a belt driven pump on the rear of the engine for the engine oil, fuel system, and power steering. The engine oil system is not a dry sump. The oil is still stored in a custom built pan with an external pick-up line. The flywheel was the hardest part of the arrangement. I worked with Bert to get the bolt pattern correct. The bellhousing is the same on the Hemi as an LA motor. After Bert did their best to get the crank bolt pattern as close as they could, I still had to modify it to get it to align properly. I ended up sending them a stock flex-plate. Hopefully, the next builder won't have any problems getting their flywheel right the first time they order.
Re: Gen 3 Hemi on dirt.. [Re: CHAPPER] #1304096
09/16/12 12:33 PM
09/16/12 12:33 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
I had good results using JW a few years back seems like it was a stock item for them but it was a 340. That dodge will stir things up but we know its driver and chassi set up that will win no matter what brand of power.
Re: Gen 3 Hemi on dirt.. [Re: Cheatham] #1304097
09/16/12 12:46 PM
09/16/12 12:46 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
I have used the JW 'wheel' in the past. It works fine with a stock type starter/bellhousing.
Re: Gen 3 Hemi on dirt.. [Re: CHAPPER] #1304098
09/16/12 09:17 PM
09/16/12 09:17 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Really cool, what track does that dude race at?
Re: Gen 3 Hemi on dirt.. [Re: 340RICK] #1304099
09/16/12 10:04 PM
09/16/12 10:04 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
The local/closest tracks are Skyline Speedway, Hilltop(the legendary), Ohio Valley, Jackson County, Interstate, West Virginia Motor Speedway, Tyler County
Re: Gen 3 Hemi on dirt.. [Re: CHAPPER] #1304100
09/17/12 01:22 PM
09/17/12 01:22 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Looks like a screamer
Rich H.
Esse Quam Videri
Re: Gen 3 Hemi on dirt.. [Re: CHAPPER] #1304101
09/17/12 01:37 PM
09/17/12 01:37 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
How often do the engines themselves get hurt in crashes? Don't know if that is a factor when chosing an engine - replacement engine parts from crash damage.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Gen 3 Hemi on dirt.. [Re: Shoozy] #1304102
09/21/12 08:49 AM
09/21/12 08:49 AM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
Re: Gen 3 Hemi on dirt.. [Re: CHAPPER] #1304103
09/21/12 08:51 AM
09/21/12 08:51 AM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
Supposed to test the car at 9 AM Saturday,,weather permitting,,I will take MY camera. Then, maybe, I can post some good pics of this thing!!
Re: Gen 3 Hemi on dirt.. [Re: CHAPPER] #1304104
09/22/12 12:18 PM
09/22/12 12:18 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
At the test..
Re: Gen 3 Hemi on dirt.. [Re: CHAPPER] #1304105
09/22/12 12:19 PM
09/22/12 12:19 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
more
Re: Gen 3 Hemi on dirt.. [Re: CHAPPER] #1304106
09/22/12 12:20 PM
09/22/12 12:20 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
Re: Gen 3 Hemi on dirt.. [Re: CHAPPER] #1304107
09/22/12 12:21 PM
09/22/12 12:21 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
Re: Gen 3 Hemi on dirt.. [Re: CHAPPER] #1304108
09/22/12 12:22 PM
09/22/12 12:22 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
Re: Gen 3 Hemi on dirt.. [Re: CHAPPER] #1304109
09/22/12 12:22 PM
09/22/12 12:22 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
