Getting my new 440 dyno this week #1302680
09/12/12 07:38 AM
09/12/12 07:38 AM
Frederick, MD
moparguy1967 Offline OP
Frederick, MD
So I'm having my new 440 dyno ed this Friday. This is my first professional build motor and dyno tuning. I purchased a short block off another member on here back in June. He had new rings and bearing installed at Jensens engine tech in PA. So I took my top end and cam to Jensens to have him complete the job. I'll list the specs on the motor below. I picked up the motor last week to paint and make sure that my current accessorys will work. Now it is almost ready to go back. I know that on the dyno, he will break the motor in, install the inner springs, and reset the valve lash. Then tune the carb as needed.
Now the questions.
What questions should I be asking at the dyno session ?
What kind of power do you think the motor will make?
30 over 440
Ross forged pistons
10.5 to 1
Scat h-beam rods
Forged crank
906 heads with larger SS valves. I don't know the size.
Had the bowls blend for the new valve cut.
MP 284/528 solid cam
Crane gold 1.5 rockers
E-Brock rpm performer
Pro systems 4150 / built for this set up
HP manifolds. I won't beable to use my manifolds at the dyno. He has headers to use.
I think thats everything.
Re: Getting my new 440 dyno this week [Re: moparguy1967] #1302681
09/12/12 07:52 AM
09/12/12 07:52 AM
The Great White North
RAMM Offline
RAMM  Offline
Now the questions.
30 over 440
Ross forged pistons
10.5 to 1
Scat h-beam rods
Forged crank
With headers I would think you will might be a little over the 500 hp mark and 509-513 ft/lbs. With manifolds a lot less. Either way a day on the dyno can be a lot of fun and I'm sure you will have a nice engine on your hands. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Getting my new 440 dyno this week [Re: RAMM] #1302682
09/12/12 08:18 AM
09/12/12 08:18 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Should run pretty good. close to 500. I will say if you tighten the lash up a little w/ the 528 it runs better. I tighten a 528 up to .024/.026 and it seemed to have more "range". I don't think w/ the 528 you need to remove the inner spring for break in, they are pretty whimpy cams.
Coming soon!!!!
Re: Getting my new 440 dyno this week [Re: Mr.Yuck] #1302683
09/12/12 11:43 AM
09/12/12 11:43 AM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
You will lose about 7-10% horsepower with the manifolds. I just had my motor on a dyno. It made 501 w/headers 468/manifolds so less than 7% loss.
What was I thinking....
Re: Getting my new 440 dyno this week [Re: 72blubird] #1302684
09/12/12 12:24 PM
09/12/12 12:24 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
If a bowl cleanup was all the port work done, I'd say this combo is good for 425 hp. I doubt that this engine will run on pump gas with that compression and 906's unless it is a quench motor.The manifolds don't help. Good cam choice though.
Re: Getting my new 440 dyno this week [Re: Lee446] #1302685
09/12/12 01:25 PM
09/12/12 01:25 PM
Nebraska
70VcodeCoronetRT Offline
Nebraska
72blubird, what were the torque differences? Oh and I'm going to say 488hp
Re: Getting my new 440 dyno this week [Re: 70VcodeCoronetRT] #1302686
09/12/12 01:49 PM
09/12/12 01:49 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I am pretty much right in line with J Robb on the how it will do.
I would definitely stick with the plan of keeping the inner springs out for break in. It's not just the baby lobes we have to look at,but seat and over the nose spring pressure.
Too much spring can kill any cam during break in,in my opinion. Better safe than sorry.
Hopefully your dyno guy has a small set of headers ,not quite as good as running what you have for the car but would be closer than a typical large tune header
Keith
Re: Getting my new 440 dyno this week [Re: Dunnuck Racing] #1302687
09/14/12 08:56 PM
09/14/12 08:56 PM
Frederick, MD
Frederick, MD
I just got home the day went great.
http://www.youtube.com/watch?v=OOIgewNRCxk&feature=youtube_gdata_player
Peak hp 520 at 5600
Peak tq 560 at 4500
Makes over 400 ft-lbs from 2500 to 6000
Re: Getting my new 440 dyno this week [Re: moparguy1967] #1302688
09/14/12 09:25 PM
09/14/12 09:25 PM
pa
FOXY312 Offline
FOXY312  Offline
pa
I had my 440-6 done by Andy Jensens in p.a and dyno too.The guy is great gave me 600hp.
Re: Getting my new 440 dyno this week [Re: FOXY312] #1302689
09/14/12 10:47 PM
09/14/12 10:47 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
That was cool and 520 out of cleaned up iron heads is great!
Re: Getting my new 440 dyno this week [Re: Dodgem] #1302690
09/14/12 11:03 PM
09/14/12 11:03 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Interesting: I did the same build, 528 solid, Ross flat tops but with a factory six pack setup and I ported a set of 915's for a quench engine. That was in my 71 Road Runner, it was a nice engine for that heavy car and ran well.
Sheldon
Re: Getting my new 440 dyno this week [Re: moparguy1967] #1302691
09/14/12 11:17 PM
09/14/12 11:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Peak hp 520 at 5600
Peak tq 560 at 4500
NICE..........
Re: Getting my new 440 dyno this week [Re: moparguy1967] #1302692
09/14/12 11:49 PM
09/14/12 11:49 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Peak hp 520 at 5600
Peak tq 560 at 4500
Nice numbers!! Let us know how it runs at the track!
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Getting my new 440 dyno this week [Re: Von] #1302693
09/15/12 08:07 AM
09/15/12 08:07 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Me thinks the 906s are a tad more than just "cleaned up"
I had rebuilt 906s with a professional valve job on my 438" stroker in a 383 block. simply bolting on edelbrock heads felt like I picked up about 50 hp, and on the engine dyno with the eddy heads, it only made 505hp, 535 tq, (over 500 ft lbs from 3000 rpm through 5500 rpm)
VERY similar build though...but I was running the Comp XE-275-HL hyd cam. 275° advertised, around 230° @ .050 (I forget the actual specs), .525 lift
**Photobucket sucks**
Re: Getting my new 440 dyno this week [Re: moparguy1967] #1302694
09/15/12 08:38 AM
09/15/12 08:38 AM
NC
440Jim Online work
440Jim  Online Work
NC
Peak hp 520 at 5600
Peak tq 560 at 4500
You should be very happy with the results.
I was a little surprised the torque peak was that high (rpm).
The MP 0.528" cam is very mild and has good street manners, as you found it will go to 6000 rpm with headers, etc.
What size were the dyno headers? Maybe that raised the torque peak. I would guess the headers vs exhaust manifolds are around 30 hp.
Re: Getting my new 440 dyno this week [Re: 440Jim] #1302695
09/15/12 07:17 PM
09/15/12 07:17 PM
Frederick, MD
Frederick, MD
Peak hp 520 at 5600
Peak tq 560 at 4500
The headers he had were old and beat up. I would say they were 1 3/4".
I had read somewhere that with a small lift cam( around .500 with lash), that header would not make as much of a difference as you would think. Something about air velocity and such.
Re: Getting my new 440 dyno this week [Re: moparguy1967] #1302696
09/17/12 01:52 PM
09/17/12 01:52 PM
Frederick, MD
Frederick, MD
