Re: how do you guys get to this weld [Re: earthmover] #1302491
09/12/12 10:02 AM
09/12/12 10:02 AM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
If I was doing it I would run a bead to the tube only that going up,then make the weld that tie the front tubes, then welded the tubes to that bead made on the back tube.It sould be a good up hill weld.
Section 8 Racing We are nuts about racing.
Re: how do you guys get to this weld [Re: bentwheel43] #1302492
09/12/12 12:21 PM
09/12/12 12:21 PM
nc
E
earthmover Offline OP
E
nc
this is whre that weld needs to be done but on the side closer to the outside of the car.. it has the bar from the main hoop ,kidney bar,and bar that runs from the front to the main hoop.. it has been welded except about 2" maybe.. can i stick it or mig it best i can and add a tab on the inside the tie all points tog..??? just a thought...
Re: how do you guys get to this weld [Re: earthmover] #1302493
09/12/12 02:24 PM
09/12/12 02:24 PM
Aubrey, Texas
O
oldtimer5151 Offline
O
Aubrey, Texas
Get a friend over with a big pry bar and do like MR.P suggested and mig weld it with shielded gas. You will have to weld a little on both sides to complete the weld.
Re: how do you guys get to this weld [Re: oldtimer5151] #1302494
09/12/12 04:11 PM
09/12/12 04:11 PM
sweden
sshemi Offline
sshemi  Offline
sweden
If your used to it stick weld.
Re: how do you guys get to this weld [Re: sshemi] #1302495
09/12/12 05:31 PM
09/12/12 05:31 PM
Renton Washington
Triple Threat Offline
Renton Washington
Not if you want to pass tech in the states.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
