Gen lll Hemi oil system mods
#1302357
09/11/12 10:24 PM
09/11/12 10:24 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
Anyone know what mods (if any) are neccesary to make a Gen III live in a race enviroment. They were alluded to in a previous post and also when I was quizzing a local Drag Pack owner. The S/S guy didn't want to give up his secrets, not that I blame him. If anyone has any insight I would appreciate the help. I dont really want to learn the hard way. I already have a forged rotating assy. and a high volume oil pump. I plan on keeping the rpm to 7500 max.
DAve
Re: Gen lll Hemi oil system mods
[Re: LA360]
#1302359
09/12/12 09:11 PM
09/12/12 09:11 PM
Dave_S
I guess your right. Those who know seem to be keeping it to themselves.
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
[Re: Dave_S]
#1302360
09/13/12 09:35 AM
09/13/12 09:35 AM
Posts: 528 Oak Grove, MN
lowflyingdart
Oak Grove, MN
Are you building a stroker engine?
"I have not failed. I've just found 10,000 ways that won't work."
Thomas A. Edison
[Re: Dave_S]
#1302362
09/14/12 12:24 AM
09/14/12 12:24 AM
Posts: 833 MN
hemidup
MN
What oil pan you plan on using and how many qt's?
Jerry Williams.
[Re: hemidup]
#1302365
09/18/12 06:56 PM
09/18/12 06:56 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
Keep the oil squirters, take the lip out of the oil pump where the pick up tube meets and get an accumulator. The HYD lifters will be fine.
That will be more than enough. These engines don't have oiling issues.
Alex. He's building a 5.7. They don't have oil squirter's.
Let me ask a question. Lets say we have 2 oil pumps that produce the same amount of oil pressure at rpm. One being stock and the other a high volume. Here is the question. Would you rather have more oil in the heads or in the oil pan?
Thats a compromise. I'd like to have the valve train very well lubricated but dont want the springs drowning in it.
For most uses, I'd feel comfy with plan C...4 quarts in the sump (or draining down), 2 floating around up top and a qt in the accumulator just in case.
[Re: AlexP]
#1302366
09/18/12 07:53 PM
09/18/12 07:53 PM
Posts: 7,664 IN
ahy
IN
I think its a trick question... with the engine at speed and the same oil pressure, oil flow through the engine will be the same. The HV pump will just be dumping more out the bypass and back into the pan... and using a little extra power and heating up the oil more.
The main benefit of the HV pump is at low RPM/hot oil conditions where a stock pump may not make enough flow and pressure with increased bearing clearances.
[Re: ahy]
#1302367
09/18/12 08:43 PM
09/18/12 08:43 PM
Dave_S
Thanks for the input guys. This web site has lots of good info as well: http://monstermopar.com/forum/index.php?board=43.0Seems like the biggest problem is oil pump cavitation at higher rpm. The fix seems to be porting the inlet side of the pump and ensuring adequate drain back from the heads. Dave
[Re: CHAPPER]
#1302370
10/11/12 05:01 PM
10/11/12 05:01 PM
Posts: 3,998 GO BUCKS !!!!!!!
340RICK
GO BUCKS !!!!!!!
I am not expert but play one on here. My 6.1 storker has a stock oil pump and has plenty of PSI. (75PSI) I would not use a HV pump its not needed, I feel these motors already pump plenty of oil to the top end. Make sure that the oil pan you use has the dimples in the pan rail and does not cover up the drain back holes in the rail of the block. I am using a custom Charlies 7Qt pan with kick out and the factory oil pan gasket/windage tray.
[Re: 340RICK]
#1302371
10/11/12 07:14 PM
10/11/12 07:14 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Thanks Rick, but,that's all ya' got..?? I'm looking for MORE info. I've got/had ALL those things covered....still lost a #4 rod. The concensus/opinions of the people I have talked to, that have had rod failures,, all with #3 or #4 rod,, seem to think the crank is the problem. Don't want a pizzn match,, just trying to get some experienced opinions. I know that is hard here,, . I am talking oil problems in the 7500-7800RPM range. I don't know what anybody else is turning, but I was impressed with how these things rev. The motor was COMPLETELY upgraded internally...no stock stuff in it other than the crankshaft/block.
If you like drag racing, support your local track.
[Re: CHAPPER]
#1302372
10/11/12 08:56 PM
10/11/12 08:56 PM
340RICK
GO BUCKS !!!!!!!
Dont Pizz me off I am running a Manley 4.050 crank I have had my 6.1 to 7500RPM many times and its still pulling, been to chicken to go any higher. I am running more camshaft than the drag pak motors, with ported heads so I would assume mine would like some more RPM, but on dyno and at track I have shut it down at 7500rpm so far. I am going to pull pan off my motor this winter and take a peaky poo at the rods and mains just for safety sake. I have a system one filter on since day one and its been clean as a whistle and I check it often. I also have a oil temp guage in car as well and it stays fully warmed in the 170-180 range max
[Re: CHAPPER]
#1302374
09/13/13 07:15 PM
09/13/13 07:15 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
I like to bring this topic up again for an issue I just noticed with my 5.7Hemi. Looking at/into the oilfilter mount, I noticed 2 little holes in the casting, alongside the inlet-port into the oilfilter. The side holes were formed because the casting was thin enough there to break away. Some gentle poking caused the edges of the holes to chip away some more very easily. I've enlarged and camfered one of the holes into the inlet-port and plan to do the same with the second hole. If I'm correct this is the pressure-side of the pump, right before the oil goes into the oilfilter. First pic shows the as-found situation. Second pic shows the modified situation. Third pic shows the remaining castinghole I plan to open up and blend into the filter area. Any thoughts? "Original" "Modified" Other casting hole;
[Re: SC304]
#1302376
09/16/13 10:29 PM
09/16/13 10:29 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
So the 6.1 crank is proven to oil good up to 7500-8000 ok? When the Drag Pack first were speced out they said stock cranks?? Heres mine I was messin with last night.
Mopar to the bone!!!
[Re: 72Swinger]
#1302377
09/17/13 08:05 AM
09/17/13 08:05 AM
Posts: 2,826 NY usa
540challenger
NY usa
He did say reworked, What ever that means but i doubt a 6.1 crank in stock form could do that.
[Re: dizuster]
#1302379
09/17/13 10:30 AM
09/17/13 10:30 AM
72Swinger
Nebraska
I actually haven't heard it said about 6.1's , but have seen the results of the 5.7 cranks from Chapper.
[Re: Triple Threat]
#1302383
09/17/13 10:13 PM
09/17/13 10:13 PM
Posts: 3,433 Toronto
mshred
Toronto
HHP told me that they have a bunch of them turning 7500@ over 1000hp on their turbo stuff.
I'm not sure where the whole "6.1L cranks can't turn RPM" came from. But the more people I actually talk to, the less I believe the moparts masses that preach it.
The mopar masses are preaching what David Barton says is the problem. Given his success with the Gen 3 hemi stuff, I would be inclined to listen.
x2...Barton says there is an issue, won't say what it is thought, masses are too scared to try and push the limits themselves when they are told there is an issue, and voila lol
Kinda sucks though that this info is not readily available or being shared...I mean really if this gen III hemi thing is going to ever take off other than in drag pak and in the LX platform cars, some info needs to be shared and the veil pulled off so to speak
[Re: mshred]
#1302385
09/18/13 03:46 PM
09/18/13 03:46 PM
CHAPPER
Belpre,Ohio
A Molnar crank and rods from Chuck Lofgren cured my oiling problems. Motor is back out and running fine. Has over 200 laps of dirt tracking on it without any problems. Using the same belt driven Barnes oil pump set-up as before.
[Re: CHAPPER]
#1302386
09/18/13 10:52 PM
09/18/13 10:52 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
What is high rpm? 6500? 7700? 8800?
Call Molnar and he would be glad to explain your high rpm oiling issues with a stock 6.1 crank. He was very helpful with me.
I am guessing most on here do not need his crank, unless you plan on spinning it harder than say 7500. (Assuming you are staying with stock stroke)
A stocker or super stocker wanting to spin high rpm would benefit from having the crank he manufactures.
With all this said, I am going to be keeping a stock 6.1 crank turned down, but it would be nice to have the Molnar crank.
Justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
