Re: dakota 5-speed in an a-body?
[Re: Mr.Yuck]
#130198
09/30/08 04:03 PM
09/30/08 04:03 PM
Posts: 574 Western New York since 2000
dart44072
super gas
super gas
You'd think but they are not. I must have called 20 places in order to find one for my 5.2 dakota. and they are about $500 more because of that. I had to have mind rebuilt ($1200) keep that in mind when you buy it.
[Re: dart44072]
#130199
09/30/08 04:26 PM
09/30/08 04:26 PM
Posts: 300 MA
Greg55_99
MA
[Re: dart44072]
#130200
09/30/08 04:31 PM
09/30/08 04:31 PM
Posts: 1,072 Louisville, KY.
Scottmon
Louisville, KY.
You'd have to cut the floor up and fab a x-member but I'd think you could make it work. Make sure it's one for a V8
Wouldn't the V-6 be the same?
V-6 uses an AX-15 tranny...weak. 5.2 uses an NV3500, better but build the motor much or get a lot of traction dropping the hammer and you'll munch the tranny.
[Re: Scottmon]
#130202
09/30/08 07:01 PM
09/30/08 07:01 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
My 95 dak sport is pretty stock and runs 14.0's or has. at the expense of 2 rears (under warrenty) and well the original trans lasted a while 130k but was really whining around the 100k mark. I got a unit from the yard (35k so the guy said) for about $700 I put a new clutch and all in. So last year I was driving and bang stayed in 4th...finally got it unstuck, took to a trans shop and well not cheap and no used units to be had. 1st gear is ok, My truck has 3.92's and 1st gear is good for about 2 seconds. It does however produce a lot of smoke.
