Re: Edelbrock accelerator pump adjustment question
[Re: David_Trimble]
#1300557
09/15/12 08:48 PM
09/15/12 08:48 PM
RapidRobert
Yes post a pic of what they did. Is anything rubbing that should not be? If needed have you got another dizzy you can pirate a slot assy from? On top if you can find a good steel washer of the right dimentions then yes use it.
[Re: David_Trimble]
#1300559
09/15/12 09:55 PM
09/15/12 09:55 PM
RapidRobert
Oh OK I see what they did, just deburring from welding the slots to shorten them. If the round shoulder on the bottom center which contacts the plastic spacer is not ground away (looks untouched in the pic) then add a washer on top to reduce the top end play. If the shoulder was ground off I would additionally add a washer on top of the plastic spacer so the slot piece is just off of the weights to maintain the original dimention. If yours is ground I can get the amount of thickness tomorrow
[Re: David_Trimble]
#1300563
09/15/12 10:16 PM
09/15/12 10:16 PM
RapidRobert
Sounds good but go looser than .005" as you need room to manipulate the clip in and out. Just dont need .055" that you have now
[Re: RapidRobert]
#1300565
09/17/12 07:30 PM
09/17/12 07:30 PM
Posts: 738 OK
David_Trimble
OK
Well, after doing some searching and measuring this is what I've found out: I need a washer that's 7/16" OD and 5/16" ID (and at this point, you're probably beginning to see the problem). But the closest SAE standard washer I found was a #8 washer that would work on the OD but I'd have to drill out the ID to work. This is beyond what I could do with a drill press (I'm not able to come up with a way to safely hold down the washer while I drill) so I'm beginning to think I need to sleeve it instead. Failing that, that remaned distributor at O'Reilly's is starting to look pretty good... ![](/ubbthreads/images/graemlins/frowwn.gif)
'69 Dodge Charger R/T
[Re: David_Trimble]
#1300566
09/17/12 09:04 PM
09/17/12 09:04 PM
RapidRobert
hold the washer on the edge in a pair of vice grips then go slowly with your drill press. I've been wondering if your dist is the original 40+ year old unit & what shape the bushings (side play on the top slot assy) are in. I was thinking that maybe when they shortened the slots they exchanged the dist for a rebuilt one but maybe they didn't. See how much side play you have. Actually your lower end play is good from your descrip and they did no damage by deburring the welding and that was not what caused the excessive upper axial play, probably just a stackup of tolerances & now all is good only the upper play needs to be reduced to keep the rotor off of the cap terminals if the side play is good. But is the slot length they reduced it to correct for your app. But we need to solve the original complaint & worry about slot length later. As Scratchn said the rebuilt dists are a good deal for the money & you can even switch the cam/slots assy between the two as when they rebuild they only replace the 2 bushings and size them by reaming to fit the shaft as the rebuild dist will likely have the way too much mechanical (slot length) like yours originally had (36 at the crank ![](/ubbthreads/images/graemlins/blush.gif) ) before it was welded. I'd suggest get a washer under the nub, get a new cap/rotor and continue on to solve the original complaint unless your bushing side play is excessive right now. Save the old cap to drill it to check rotor phasing
[Re: David_Trimble]
#1300570
09/19/12 07:09 PM
09/19/12 07:09 PM
Posts: 738 OK
David_Trimble
OK
Well I don't know how I did it but I managed to make a washer that would fit ![](/ubbthreads/images/graemlins/punkrocka.gif) And it fits perfectly (I can't get over how lucky I was) - after I managed to get the clip back into place (I spun the clip around a turn or 2 to make sure it was in and seated) I measured the end play and got around .005". No more slop - and there's no interference from the centrifugal advance that I can tell- it operates pretty smoothly by hand. I'll oil the mechanism (it was pretty dry when I took it apart) and should have the distributor together and back in the engine before the weekend.
[Re: scratchnfotraction]
#1300572
09/20/12 08:03 PM
09/20/12 08:03 PM
Posts: 738 OK
David_Trimble
OK
Well I started reassembling the distributor today and when I got to the point where I could install the retaining collar on the lower shaft I noticed that the holes had elongated. Not by much but enough where if I'm going to do this right I might as well replace it. There's no friction fit between the pin and the collar- because of that it's hard to tell if I have correct end-play. The only place I know of to get a new collar is a dealer, and I know it'll have to be ordered- so it looks like the distributor's not going in this weekend ![](/ubbthreads/images/graemlins/bawling.gif) Edit- After looking at it again I see that the pin is a friction fit in one of the holes in the collar- but the other hole is fairly loose. If I have to I probably could live with this, but to be sure I'll replace it if I can....
[Re: RapidRobert]
#1300574
09/20/12 09:32 PM
09/20/12 09:32 PM
Posts: 738 OK
David_Trimble
OK
Cool- I'll check out Lowes this weekend of the dealer fall through then. Thanks!
[Re: David_Trimble]
#1300575
09/20/12 09:39 PM
09/20/12 09:39 PM
RapidRobert
Yes, just get a 1/2" ID one that looks similar to the OE one and if it is a bit longer no problem as there's alot of room on the shaft & nothing even remotely close that would interfere/hit. Do get several unless you're a better driller than I am ![](/ubbthreads/images/graemlins/blush.gif) and there's room around the circumference to make several pairs of holes on each one if need be to get it perfect
[Re: RapidRobert]
#1300576
09/22/12 06:42 PM
09/22/12 06:42 PM
Posts: 738 OK
David_Trimble
OK
Ok, first of all I did manage to find a couple of nylon bushings at Lowes that will work if need be. I called the dealer Friday about the collar kit but I'm told that the part number isn't coming up as being valid on the parts system, so it's no longer available (big surprise)
However, I took another look at the original collar and I think it's actually ok- I'm going to go with it and if it turns out that it's got to be replaced, well I now have some collars that could do the job.
My current question though: when reassembling the collar on the shaft I took a measurement of the end-play of the lower shaft and got a pretty low number- .002-.003. Plus I could feel a slight binding going on when I turned the lower shaft, so I took it all apart and looked again. I noticed that the upper bearing in the distributor body seems to sit up higher out of the 'floor' of the distributor body than I thought it should- about 1/8-1/4" above. This may or may not be correct, I don't know- I would've thought the top edge of the bearing would be more or less flush with the floor.
But to be sure, I thought I'd ask first to see if that's ok because if it isn't, it might explain the binding and small end-play. But if it is, then I'm wondering if I can eliminate one of the two washers that's under the centrifugal assembly, to try to get a little more end-play and less binding.
But if those two washers needs to be there though, is there anything else I can do to increase the end-play?
David
