Re: Edelbrock accelerator pump adjustment question
[Re: David_Trimble]
#1300577
09/22/12 07:34 PM
09/22/12 07:34 PM
RapidRobert
The dual point units came with 2 thrust washers and the single points only 1 so might have been a simple assembly line mistake. Take off one of the washers and reassemble it & (re)check for end play and binding
[Re: David_Trimble]
#1300579
09/22/12 08:43 PM
09/22/12 08:43 PM
RapidRobert
mock it up/check the alignment/play & I'll get back with you tomorrow
[Re: RapidRobert]
#1300580
09/23/12 04:53 PM
09/23/12 04:53 PM
Posts: 738 OK
David_Trimble
OK
Ok- without the extra thrust washer, I can get the end play to .010 (I managed to snag the Moroso distributor washer kit so I got a few different washer thicknesses to play with) with a single washer. Is that close enough? If not, I can try using combinations of washers to see if I can get it closer...
'69 Dodge Charger R/T
[Re: David_Trimble]
#1300583
09/23/12 10:29 PM
09/23/12 10:29 PM
RapidRobert
Holler if getting the dizzy squared away takes care of the stumbling. If it does not we'll keep on it
[Re: RapidRobert]
#1300584
09/24/12 09:41 PM
09/24/12 09:41 PM
Posts: 738 OK
David_Trimble
OK
Question on reinstalling the Pertronix sensor - I've got the installation sheet and it makes no mention of setting a gap between the sensor and the magnet sleeve. Is the gap critical or would just making sure there's clearance between the magnet sleeve and sensor good enough?
[Re: David_Trimble]
#1300591
09/27/12 08:33 PM
09/27/12 08:33 PM
Posts: 738 OK
David_Trimble
OK
Some progress- the distributor is back together again. The gap still needs adjustment and I'm still looking for my plastic gauge (I suspect it's out in the shed and I won't be able to get to that until the weekend) so the distributor hasn't been reinstalled yet. I did slice out a 'window' on the ruined cap between two plug wire terminals to check the gap with the corrected end-play and the new rotor with the .060" longer blade and it fits great- a much smaller gap than with the original rotor, and the rotor tip misses the bases of the plug wire terminal posts by at least a 1/8". So it looks like the original problem is taken care of... Hopefully when I find that gauge I'll be posting again this weekend to report on any changes in the engine....
