Remote oil Filter adapter pump housings
#1297274
09/04/12 02:47 PM
09/04/12 02:47 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
Well the guys that built my Chassis placed the engine to where one of the oil pump fittings interfere with the frame. Are there any Oil pumps that have the outlets for the remote filter adaper exiting from the side or rear of the pump instead of the front?
Thanks, Jim
Re: Remote oil Filter adapter pump housings
[Re: moparmanjames]
#1297275
09/04/12 03:02 PM
09/04/12 03:02 PM
Posts: 43,748 Bend,OR USA
Cab_Burge
Not that I have heard of or seen,sorry I have used a 45 degree fitting in the past out of the Milidon pump cover for the external oiling but a male straight pipe to AN fitting is better to use in my opinion and then use a sweep 90 degree fitting on the hoses Take it back and have them fix it
[Re: moparmanjames]
#1297276
09/04/12 03:58 PM
09/04/12 03:58 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
Thanks, Jim
http://www.summitracing.com/parts/MIL-21235/ Would this work. Use a remote filter The lines still go in front but there may be more flexibility
[Re: Kam*Kuda]
#1297277
09/05/12 12:52 AM
09/05/12 12:52 AM
moparmanjames
Las Vegas NV
Thanks, Jim
Thanks, I have a spare milodon that I might try and modify to come out the side instead of the front. I seem to remember that there was a nice Kieth Black pump, very pricey though. I can't find it though.
[Re: AndyF]
#1297279
09/05/12 11:46 AM
09/05/12 11:46 AM
Posts: 31,203 Oregon
AndyF
[Re: AndyF]
#1297280
09/06/12 02:15 AM
09/06/12 02:15 AM
moparmanjames
Las Vegas NV
Like this?
Yes Andy thanks! who makes that?
[Re: J_BODY]
#1297283
09/06/12 01:16 PM
09/06/12 01:16 PM
moparmanjames
Las Vegas NV
That thing going to hit the track soon Jim? I sold the Mirada after a 28 year run. Going to be out in our 70 Duster in the spring hopefully. Going back to the "no fuss" 11 sec combo.
Hopefully I'll have it at the Thanksgiving race but it's going very slow due to my work schedule. I work out of town 90% of the time so I'm hoping to get enough time to get it together by then. Should run mid 9's in Vegas. Hope to see you some time in the spring, that Duster of yours is kick a$$.
[Re: fishy340]
#1297284
09/06/12 01:17 PM
09/06/12 01:17 PM
moparmanjames
Las Vegas NV
i believe Andy makes it,ar products...Andy do you guys have any for a sb like that? thanks AndyB
Thanks I'll try and find it.
[Re: fishy340]
#1297287
09/06/12 10:16 PM
09/06/12 10:16 PM
moparmanjames
Las Vegas NV
mancini sells alot of his stuff,,,also hughes performance has alot of hard to find stuff..hope u get it
Thanks Andy, I sent him an email and I'm going to send a PM as well, thanks for your help.
[Re: AndyF]
#1297288
09/07/12 03:51 PM
09/07/12 03:51 PM
moparmanjames
Las Vegas NV
Another view.
It looks like I can make out the last part of "engineering" on the pump so I'm guessing it's AR Engineering.
Paging Andy, thanks!
[Re: AndyF]
#1297290
09/07/12 04:14 PM
09/07/12 04:14 PM
moparmanjames
Las Vegas NV
Yes, I made that part. It was for a guy with a Jensen who needed the oil lines to come out in the certain location. It worked really well since the oil flows in a straight line rather than having to make some right angle turns inside of a cast housing.
That wasn't a standard pump cover and it cost a bunch of money to make. Sorry, I don't have any on the shelf to sell.
Thanks, Ill try and put caps on mine and then drill and weld fitting on if you don't feel like making one. If you do, just pm me with a price and I can give you a deposit or pay in full in advance if need be. Thanks---Jim
[Re: earthmover]
#1297292
09/08/12 01:46 AM
09/08/12 01:46 AM
moparmanjames
Las Vegas NV
not to hi jack but moparmanjames do you have any inter. shoots of your duster??? what do you think it is going to weigh????oh 1 more stock frontend/tube/or strut
Well I've been a little lazy taking pics but here's one, The car will probably weigh around 3000# since I'm keeping all the glass in it and the only fiberglass is the hood. It's a coil over front end and 4x3 tube chassis.
http://i109.photobucket.com/albums/n45/moparmanjames/myduster.jpg
