Page 4 of 14 1 2 3 4 5 6 13 14
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292848
04/29/13 05:31 PM
04/29/13 05:31 PM
CJD AUTOMOTIVE Offline OP
And the filler that ties everything into the hinge post.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292849
04/30/13 09:59 AM
04/30/13 09:59 AM
Forgot one.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292850
04/30/13 11:45 PM
04/30/13 11:45 PM
Nice work. How is that apron going to work compared to the original?
Re: 1970 RoadRunner SRT8 [Re: ] #1292851
05/01/13 08:59 AM
05/01/13 08:59 AM
The SRT apron is the support structure for the strut towers. It sits about midway under the fender. The close out panel I built attaches to it further in and provides the mount for the fender (the pic with the cardboard template). This works well, as I will be able to attach the SRT splash shield in the wheel well to the Road Runner fender.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: ] #1292852
05/01/13 09:15 AM
05/01/13 09:15 AM
This might give you a better idea. Panel is not attached yet.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292853
05/01/13 10:29 AM
05/01/13 10:29 AM
Yes, I remember seeing the other pics now. You definitely are an inspiration to a lot of folk. Great work.
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292854
05/02/13 06:54 PM
05/02/13 06:54 PM
illinois
rapidtransitrick Offline
illinois
great work it'll definitely be a better car.
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292855
05/07/13 04:10 PM
05/07/13 04:10 PM
Springfield, MO- USA
Force28x Offline
Force28x  Offline
Craig, this is just amazing work.
What vehicle did the 'green' parts come from?
Re: 1970 RoadRunner SRT8 [Re: Force28x] #1292856
05/09/13 12:01 PM
05/09/13 12:01 PM
Thanks,
The parts that are green are from the SRT8. I epoxied everything after removing it (and painted the interior floor blue). The black parts are new SRT8 sheet metal, and the remaining red parts are from the SRT8 that didn't get epoxied yet. I'll go back and blast all the weld areas and epoxy everything again when done.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292857
05/09/13 12:14 PM
05/09/13 12:14 PM
Starting on the other side. Need to replace the frame rail first.
Then I can start fitting the strut tower.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292858
05/09/13 01:13 PM
05/09/13 01:13 PM
Starting to fit inner apron.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292859
05/10/13 07:38 PM
05/10/13 07:38 PM
illinois
illinois
as always you leave us wanting to see more
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292860
05/11/13 09:20 AM
05/11/13 09:20 AM
Force28x Offline
Force28x  Offline
So when will the dimensional drawings of the suspension cradle be available?
Re: 1970 RoadRunner SRT8 [Re: rapidtransitrick] #1292861
05/13/13 02:39 PM
05/13/13 02:39 PM
I'm trying!! Going to fit the rear section in the next week I hope. Need to get the suspension hung to measure for wheels. Lead time is 4-6 weeks to be custom built. Thank god I'm not on a deadline!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: Force28x] #1292862
05/13/13 03:32 PM
05/13/13 03:32 PM
It's all stock LX stuff. Don't think the cradle would help without the strut towers and stock LX suspension.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292863
05/13/13 08:44 PM
05/13/13 08:44 PM
Force28x Offline
Force28x  Offline
I'm excited to see how the interior/trunk goes together. This is just an incredibly cool thing all the way around!
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292864
05/18/13 09:30 PM
05/18/13 09:30 PM
Force28x Offline
Force28x  Offline
True, I was thinking that I could start with front end sheetmetal from a cheap 6-cylinder salvage and add SRT components later, and have the correct front end and interior sheetmetal in correct placement before I ever had to put out the cash for an SRT8 vehicle.
Re: 1970 RoadRunner SRT8 [Re: Force28x] #1292865
05/29/13 03:37 PM
05/29/13 03:37 PM
Force28x Offline
Force28x  Offline
Okay, new questions.
1) Did you replace the front rails because they moved in relationship to the stock charger firewall, or because they were damaged? They look like they are in their stock placement after welding the replacements.
2) Since you used the stock 'set' of the suspension, I'm assuming the inner apron height is close to stock. Is that a correct assumption?
Thanks in advance!
Re: 1970 RoadRunner SRT8 [Re: Force28x] #1292866
05/29/13 05:37 PM
05/29/13 05:37 PM
Thanks in advance!
1)Yes, the stock rails were damaged. I had them straightened on the frame machine and then built the jigs. They locate the front floor section, so I needed it tied into the RR before they could be replaced.
2)Everything from the SRT8 is stock and in the stock location. That's why jigs are critical. All suspension and mounts are in exactly the same locations. Nothing modified. The only modifications will be a shortened drive shaft and a little trim off the front floor sections' back to get the wheel base right.
The strut towers were removed to fit the floor section and because they have to come off to replace the rails.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: 1970 RoadRunner SRT8 [Re: CJD AUTOMOTIVE] #1292867
05/29/13 05:50 PM
05/29/13 05:50 PM
Force28x Offline
Force28x  Offline
Thanks, Craig, that is a big help. I'm thinking about using an R/T as a suspension donor, and I drive an '06 Daytona, so I can use it for ride height dimensions and jigs. I appreciate your answers, I can assume a lot from pictures, but hearing it from the source is a lot better.
Can't wait to see more progress.
