Re: STUSKA ENGINE DYNOMOMETERS??? [Re: BradH] #1291099
08/27/12 07:42 PM
08/27/12 07:42 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for sharing your experiences,Brad! Like I said earlier..my main concern for using the dyno is to make sure there are NO issues,BEFORE re-installing the engine back into the X. Setting up a good baseline tune is another reason. Horsepower and Torque data,and the RPM's the peaks are achieved..is just "icing on the cake"
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: Labratt] #1291100
08/27/12 10:57 PM
08/27/12 10:57 PM
I have always considered them a measuring toool to get results from changes made on them, I hope the one your using has AFR on both sides If it does you can get the jetting and timing in the ball park but don't consider that the ultimate tune up,I always do the final tuning wth the motor in the car For the best ET and MPH look at the time slip and adjust from there What works best on the dyno isn't always the fastest at the track
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: Labratt] #1291101
08/27/12 11:00 PM
08/27/12 11:00 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Back in the day ,,( early 70's to late 80's)I was building off shore boat motors ..I had a GO Power .D512 unit..all analog ..No computers ..just load down the load cells and read the Large torque gauge and tach ..do the math as the chart says and come out with a HP number..It didn't matter what the HP was exactly. altho it was very close...just if the tuning made more or less power... Geez..I'm getting old !!!
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: dynamite] #1291102
08/27/12 11:26 PM
08/27/12 11:26 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
That is how my builder's Stuska is set up.
Kevin
Re: STUSKA ENGINE DYNOMOMETERS??? [Re: dynamite] #1291103
08/27/12 11:36 PM
08/27/12 11:36 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks guys! I realize the tune will change with the motor hooked up and in the car. But,getting a "ballpark" idea on the tune would be beneficial! Cab...not sure if the A/F meter on the dyno is hooked to both collectors,or not! Maybe Raff,or Randy Johnson can answer that. I suppose I SHOULD have mentioned,having the rings broken-in..and finding out right off the bat,if the motor's going to "live" after a couple of 6500-7000 RPM pulls...will definately let me sleep soundly at night!
