Attaching parking brake cable to pedal on '69 Super Bee #1290955
08/25/12 01:01 AM
08/25/12 01:01 AM
BC, Canada
Black_Bee Offline OP
BC, Canada
Hey guys!
Im trying to hook up the parking brake cable to the pedal on my '69 Super Bee. Its been years since I took it off, and I have no idea how it re-attaches. I have a service manual for a '70 Coronet, and it isnt much help.
How do I attach the cable? Do I have to remove the pedal from the car before attaching it?
Thanks!
Paul
'69 Super Bee 383 EFI Turbo
Re: Attaching parking brake cable to pedal on '69 Super Bee [Re: Black_Bee] #1290956
08/25/12 02:21 AM
08/25/12 02:21 AM
Sterling Conn
manymopars Offline
manymopars  Offline
Sterling Conn
Ounce the front cable passes through the firewall, the cable will need to be inserted through the hole in the bottom of the pedal assembly. There should be a retaining clip on the cable which will lock the cable into the pedal assembly hole.All you have to do next is insert the round or cylinder shaped cable end into the swivel clasp or bracket with the slot in it.You will want to install the cable to the pedal assembly first before hooking the other end of the front cable to the rear cables.Hope this helps
Re: Attaching parking brake cable to pedal on '69 Super Bee [Re: manymopars] #1290957
08/25/12 08:43 AM
08/25/12 08:43 AM
Indiana
rapid67rt Offline
rapid67rt  Offline
Indiana
Couple of bolts in the fender well will remove the assembly. Alot easier to put the cable back in this way. Just my experience.
Re: Attaching parking brake cable to pedal on '69 Super Bee [Re: rapid67rt] #1290958
08/25/12 04:53 PM
08/25/12 04:53 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
mine too and you can clean up the assembly at the same time.
Re: Attaching parking brake cable to pedal on '69 Super Bee [Re: mikemee1331] #1290959
08/26/12 02:35 AM
08/26/12 02:35 AM
BC, Canada
BC, Canada
Thanks guys! Will pull it out to attach.
Paul
Re: Attaching parking brake cable to pedal on '69 Super Bee [Re: Black_Bee] #1290960
09/09/12 01:00 AM
09/09/12 01:00 AM
BC, Canada
BC, Canada
Hey guys!
Finally got a chance to work on this. My cable is missing the retaining clip that attaches the cable to the pedal.
What exactly does this clip look like?
Thanks!
Paul
