steering box #1290903
08/24/12 11:04 PM
08/24/12 11:04 PM
florida dade
cesar perez Offline OP
florida dade
what would be the best plaCE to buy a manuel aluminum steering box for a 71 dart or would i be able to rebuild my box thanks guys write back
Re: steering box [Re: cesar perez] #1290904
08/24/12 11:12 PM
08/24/12 11:12 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I've always have had good luck with Steer and Gear from Columbus Ohio
Re: steering box [Re: cesar perez] #1290905
08/25/12 11:07 AM
08/25/12 11:07 AM
One of the Mopar magazines did a rebuild of one & it did not appear to be complicated. Have you tried adjusting yours? You start with the steering wheel/front wheels straight ahead (box in car) or vertical shaft halfway in the middle of its' travel (box out of the car) & I dont remember the procedure exactly (see if you can locate it) but I think you adj the large ring till there is just zero play on the steering column shaft then adj the top slotted bolt down till it just makes contact then a skosh more then lock the locknut without moving the slotted bolt but do check on this. If you do rebuild yours get the 20:1 worm gear set from MP. A new/rebuild box ready to go will be pricey but I can say that going from an OE 24:1 to a 16:1 box on a circle burner was a night and day improvement
Re: steering box [Re: cesar perez] #1290906
08/25/12 01:31 PM
08/25/12 01:31 PM
scratchnfotraction Offline
what seems to be wrong with the box you have?
what part of Fl you in? dade or dade city?
on my 68 dart it would keep leaking oil,so i filled it with wheel bearing greese.
Re: steering box [Re: cesar perez] #1290907
08/25/12 06:21 PM
08/25/12 06:21 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Firm Feel does a good job rebuilding them. The 20:1 gear is nice upgrade, but hard to find anymore.
Re: steering box [Re: scratchnfotraction] #1290908
08/25/12 07:11 PM
08/25/12 07:11 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
are you serious!!! did that work? doesn't it squeal cause the grease is too thick. you're joking aren't you
Re: steering box [Re: mikemee1331] #1290909
08/25/12 10:00 PM
08/25/12 10:00 PM
talking manual steer not power steering boxes.
it worked for my alum manual steer box for yrs,every so oftern I would pull the fill plug and add a little,it would slowly poop it out the top seal/shaft.
i would also add a little gear oil to wash the greese around and thin it some,then go back to add just greese to thicking it up some so it did not poop all the time.
Re: steering box [Re: scratchnfotraction] #1290910
08/25/12 10:11 PM
08/25/12 10:11 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i can be such a 'tard sometimes
Re: steering box [Re: cesar perez] #1290911
08/28/12 06:30 PM
08/28/12 06:30 PM
midwest
afx man Offline
afx man  Offline
midwest
http://www.borgeson.com/xcart/home.php?cat=144
You could try borgeson I like their products.
