Re: Back to square one [Re: Alexdodge] #1289904
08/23/12 03:00 PM
08/23/12 03:00 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Your not the first person to have trouble making a 600 eddy run right!
I had one once on a cammed 318 did everything recurved dizzy step up spring kit jetting hard to get an nice idle and power surged a cruise.
Holleys worked fine on the same motor??
Sold it to a friend and we but it on a box stock 318 just an intake to fit the 4 barrel and it ran perfect???
Maybe eddy should state these are for box stock engines only???
Who knows
Think some are worse than others??
But we made two of them work on my buddies 440 edelbrock 2 x 4 intake and later on a cross ram???
Re: Back to square one [Re: Alexdodge] #1289905
08/23/12 03:09 PM
08/23/12 03:09 PM
Alex, check the total timing revved up until it stops advancing, make sure it isn't any higher than 34 to 36 degrees BTDC. Most Mopar SB with iron heads like between 30 and 34 degrees total adavnce, depending on the gas and altitude your driving in You may find that your distributor can be adjusted internally to limit the total advance by shortening up the slots that the mechanical weights that advance the rotor can travel in I like to see around 16 to 18 degrees at idle and 32 to 36 degrees total on my Mopar BB and 426 Hemi motors, 30 to 32 degrees toatl on the SB Mopars I build and tune IHTH I use the weakest springs I can buy for the weights in the distributor, Mr Gasket sells some really weak ones for Chevy distributors that work real well in our distributors
Re: Back to square one [Re: Dodgem] #1289906
08/23/12 03:11 PM
08/23/12 03:11 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I've been running and changing the tuneup because I take it to other areas of the country and drive it with a 1405 600 for over 20 years now.
With a big cam it's needs plenty of timing and weak springs so the neddles stay down at idle. I think I'm running the weakest springs, but I'm not sure until I look at my notes.
Re: Back to square one [Re: Cab_Burge] #1289907
08/23/12 04:13 PM
08/23/12 04:13 PM
Eastern ohio
Alexdodge Offline OP
Eastern ohio
Cab Bruge, I'll sure check that out tomorrow, Thanks, Alex
Anyone interested in a 600 eddy? Never been on the street more than 10 minutes.
Re: Back to square one [Re: Alexdodge] #1289908
08/23/12 05:21 PM
08/23/12 05:21 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i'm sure they're decent units (never used one) but if anybody PM's you an offer let them know i've got some swamp land for sale!
Re: Back to square one [Re: Challenger 1] #1289909
08/23/12 06:09 PM
08/23/12 06:09 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Had me at a loss a 600 holley vac with a 5.5 power valve ran perfect. 3310 holley 5.5 power valve vac seconds ran perfect and with that the little 318 ran 15.74 street tires through the exhaust in a 78 D100. even my 800 DP with 5.5 power valve ran perfect on it??
In the end had the lightest step up springs and timing all in by 1200.
put a 800 thermo bog on it was a little testy but never played with the step up springs it sure liked it a full throttle but the 600 holley was nice and smooth so that's what lived on it the most!
It was a long duration cam (erson of some size I measured the duratoin 0 to 0 at 305??) did not know enough to do @.050 way back then. 318 with 360 heads was about 7 to 1
Re: Back to square one [Re: Alexdodge] #1289910
08/24/12 12:37 AM
08/24/12 12:37 AM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
If you changed the cam and lifters and the motor had original pushrods, the pushrods are probably 1/8" too long. Chrysler changed the length of pushrods in '68 or '67, because of a higher seat location in the lifter. I had the same problem in a '66 383 several years ago.
Re: Back to square one [Re: PLUM BAD] #1289911
08/24/12 03:17 PM
08/24/12 03:17 PM
Eastern ohio
Eastern ohio
Plum bad, I checked the pushrods and the are the newer ones. When I went to put them back in I bent one of the rods. Just ordered a new set from summit. comp brand
