Re: HORSEPOWER GAINS FROM HEAD WORK???
[Re: firefighter3931]
#1289525
08/22/12 05:25 PM
08/22/12 05:25 PM
Posts: 2,935 Finalnd, Perkele
jyrki
Finalnd, Perkele
Depends of what your engine is lacking. You may even loose something if your combo isn't right to the right direction. Head flow is not a key factor. Otherwise everyone would be running hemis.
Plynouth VIP '67 TT IC EFI
[Re: BradH]
#1289526
08/22/12 05:31 PM
08/22/12 05:31 PM
BradH
I'd want to see 60-70 HP for those changes.
FWIW, my car drops close to .1 in ET for each 10 HP I've added, so I'd think you could see up to .5 in ET improvement as long as the rest of the combination still works with it.
[Re: BradH]
#1289527
08/22/12 06:20 PM
08/22/12 06:20 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I think you will see around 3 to 4/10. I run the exact same heads as you, also milled .050 and i changed from mild port 452's with big valves and a torker man, to my present heads and a victor man and picked up nearly 7/10 and 6 mph. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1289528
08/22/12 11:22 PM
08/22/12 11:22 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Mick, still same short block? Sounds like you are doing good eh? Good tohear, Don
[Re: BradH]
#1289529
08/23/12 12:07 AM
08/23/12 12:07 AM
Posts: 2,325 Clinton Twp... north of Deetro...
Labratt
Good Ol Randy B!
Good Ol Randy B!
Brad...a .5 improvement would put a HUGE smile on my face! Looking at the cam's duration specs on Dulcich's 448..they seem a little anemic for cnc-ported heads that flow as well as Jeff's do. I'm willing to bet if that motor had my 262/266 @ .050 duration cam..he would have been seeing a bit more than a 46 horsepower increase! Thanks for that info Brent! Thank You all for your opinions on this! Randy B.
[Re: Labratt]
#1289530
08/23/12 12:29 AM
08/23/12 12:29 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Randy, that SQ Cam will respond favorably to the increased compression and head flow. Expect a nice improvement in torque and horsepower and the midrange should be significantly improved. The stall speed will increase so the short times will improve and it will launch harder. Hopefully it'll hook and if it does that will translate to better ET's and higher trap speeds. A reasonable expectation would be 50hp based on the bump in comp and port work. How much that improves the ET/MPH remains to be seen but like I predicted in the other thread ; it will run into the 10's I'll go out on a limb and predict 10.85@124...hopefully better ! Ron
#1289531
08/23/12 04:15 AM
08/23/12 04:15 AM
deaks
robin hood country
HI Don The motor i'm refering to, is my old motor but the short block i got off you is still going good thanks. Sorry about the hijack Randy, as you were. Mick
[Re: jyrki]
#1289532
08/23/12 05:04 AM
08/23/12 05:04 AM
Posts: 2,141 junction city oregon
viperblue72
Head flow is THE key factor to making horsepower. I guess you are just saying the combo has to be right jyrki? And everyone WOULD be running hemis if they were cheap.
Labratt my guess is about 60 horsepower gain. In the seat of the pants that is alot. It will be a completely different animal. You can say goodbye to the 11s.
#1289533
08/23/12 09:30 AM
08/23/12 09:30 AM
Labratt
Good Ol Randy B!
Good Ol Randy B!
I'll go out on a limb and predict [Email]10.85@124...hopefully[/Email] better !
Ron
[Re: Labratt]
#1289537
08/23/12 09:28 PM
08/23/12 09:28 PM
Posts: 10,088 Frostbitefalls MN (Rocky&Bullw...
gregsdart
R&J out of Iowa did my heads originally, and they ran the fastest that way. I tried some bigger valves, but they didn't help dispite showing flow gains. I have 440-1 heads.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: Brian Hafliger]
#1289539
08/24/12 12:49 AM
08/24/12 12:49 AM
Labratt
Good Ol Randy B!
Good Ol Randy B!
I'm positive that good port flow is ONE piece to the puzzle. Not the most important piece but important none the less.
Brian..I agree 100%! If I didn't think the head work would make a BIG improvement...no way would I have spent the money that I did on them! Randy
[Re: 5spdcuda]
#1289542
08/24/12 10:06 AM
08/24/12 10:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I tend to be conservative in my power estimates. My best guess and thats all it is would be 30-40 on the port work and 20 on the compression increase. A lot will depend on whether or not the rest of the combo can take advantage of the port work. The law of diminishing returns has never been repealed. Increasing compression from 8:1 to 9:1 will result in X amount of increased power. Going from 9:1 to 10:1 will result in something less than X and so on as the ratio increases the results diminish. Just see what your trap speed changes by. The old rule of thumb is 1 mph = 10 hp. Of course as speed goes up areodynamic drag enters into this since drag increases at the square of speed. As speed increases the power required for each increase also goes up.
Yep... its definitely on a bell curve
[Re: Labratt]
#1289543
08/24/12 10:21 AM
08/24/12 10:21 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Hi,Greg! What heads do you have...and who ported them? Thanks!
Randy they are just a set of 915's........and I ported them
