Do You Know Mopar Wiring? #1289383
08/21/12 11:15 PM
08/21/12 11:15 PM
Iowa
Hey19 Offline OP
Hey19  Offline OP
Iowa
If you do please help me with this one. I am building a street rod and I am using a 80's column where the turn signals, brakes and taillights were on or partially on individual bulbs. However I am using single taillights on the rod with dual element single bulbs (1157). There is a common way of doing this to get brakes and turn signals to work together on one of the filaments by using a tail light controller from the RV - trailer industry. It lets you hook a single tail light trailer to a multi light truck. I am having trouble getting mine to work right. Here is the question - late 60's RR, GTX, barracuda all had single bulb dual element tail lights for stop turn and tail. In the era of no solid state trailer controllers how did the factory make that work???
Re: Do You Know Mopar Wiring? [Re: Hey19] #1289384
08/21/12 11:30 PM
08/21/12 11:30 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
The turn signal switch separates the brake/turn signal function. Here's a link to a recent post about it.
https://board.moparts.org/ubbthreads/show...rue#Post7337485
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Do You Know Mopar Wiring? [Re: Hey19] #1289385
08/21/12 11:38 PM
08/21/12 11:38 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Wiring.
A constant hot wire went to the brake switch. (RE in the example)
This signal (Off/On) was directed up through the turn signal switch. (WH in the example)
No turn signal? it went straight through, feeding only the rear lights.
Turn signal? This completed a circuit ON THE TURN SIGNAL SIDE to route the ign on TS power thru the flasher (RE again here) to the front and rear bulbs. The other side was still connected straight through.
Re: Do You Know Mopar Wiring? [Re: RodStRace] #1289386
08/22/12 09:07 PM
08/22/12 09:07 PM
Iowa
Hey19 Offline OP
Hey19  Offline OP
Iowa
Thanks for the replies. You were right on with the diagram/explanation. I didn't remember that the brakes went through the steering column, I was assuming that the white brake wire was for a dash light as my print calls it a "stop lamp". I hooked it up to the tail lights as shown in your print and my system works perfect. I really appreciate the help.
Re: Do You Know Mopar Wiring? [Re: Hey19] #1289387
08/23/12 12:24 AM
08/23/12 12:24 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Glad to help and VERY happy you came back and followed up.
Some here just ask, get the answer and never give feedback.
Re: Do You Know Mopar Wiring? [Re: RodStRace] #1289388
08/23/12 08:14 AM
08/23/12 08:14 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
which can be very annoying for posters and folks who use the search engine! luckly here on Moparts, everyone is right .
