Re: HORSEPOWER NEEDED TO RUN 10.8-10.9'S ???
[Re: Thumperdart]
#1288943
08/21/12 12:48 PM
08/21/12 12:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Also Randy when you were on Garys dyno you had the 850 on it and we know you make more power with the bigger carb so figure that in also ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Labratt]
#1288944
08/21/12 12:49 PM
08/21/12 12:49 PM
Posts: 7,506 Az
Crizila
Az
Trying to determine HP using ET is a crap shoot at best - so - using my trusty Moroso "power speed calculator", and pluging in 3700 lbs and 500 HP, I came up with an ET of 10.95.
Fastest 300
[Re: Crizila]
#1288945
08/21/12 12:55 PM
08/21/12 12:55 PM
MR_P_BODY
He could probably do it with 520hp being that he doesnt 60ft real well.. but that would be about the minimum... once he's rolling its fine... if he got the 60' down to a 1.50s he could bump into the 10s now(barely) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: BradH]
#1288947
08/21/12 01:56 PM
08/21/12 01:56 PM
Posts: 861 lancaster,california
johnnycuda
My 'Cuda runs 10.70's at 125,on the chassis dyno it made 495hp,my car weighs 3770 with me in it,has full length exhaust thru the Cuda tips,4.56 gear,28in tall tire,my car doesn't 60' very well,only 1.61/1.62..so obviously there's more there if I can get it to 60'.My runs were at Fontana Dragway,a little above sea level I believe.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: RobX4406]
#1288949
08/21/12 02:45 PM
08/21/12 02:45 PM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
My cuda went 10.40 at 129 mph at 3700# w/ 508 rwhp...on a Dynojet chassis dyno. On an engine dyno, that combo should have been somewhere around 620 hp. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: an8sec70cuda]
#1288950
08/21/12 03:54 PM
08/21/12 03:54 PM
Posts: 2,325 Clinton Twp... north of Deetro...
Labratt
Good Ol Randy B!
Good Ol Randy B!
Mike,the 440 liked your 850..and Brad's,and Russ' 950HP even more...at least at the track! ![](/ubbthreads/images/graemlins/thumbs.gif) Brad,Gary Jacob's(Jake68)chassis dyno is a DynoJet. Rob,the GTX usually 60's in the 1.52-1.56 range. Do you guys agree with the 80-100 hp increase from the head work? I believe,if I can get decent traction..and run 1.49-1.50's,I could hit my 10.8-10.9 goal. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) BTW..the engine dyno at St. Clair Engine,where I'll be running it,is a Stuska..which is a division of Power Test Inc. Anybody here know how accurate these are? ![](/ubbthreads/images/graemlins/shruggy.gif) Thanks! Randy ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Labratt]
#1288951
08/21/12 04:11 PM
08/21/12 04:11 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
That's a pretty good 60'. Must have been something else that I saw about 1.60 time. The extra HP may help your 60's. If you hit 1.50 or better, the time you want should be in range. Dynos, both chassis and engine, are all over the map, no consistency. Tuning tool, great; reality, not so much most of the time. And EVERYONE claims the dyno used was stingy! ![](/ubbthreads/images/graemlins/smile.gif) Seen one where the engine alleged to make 560hp, 3200 pound car, ran 121-122. I'd be REALLY disappointed if that was my ride because something isn't right. Good luck, should be fun!
[Re: Labratt]
#1288954
08/21/12 04:56 PM
08/21/12 04:56 PM
MR_P_BODY
Mike,the 440 liked your 850..and Brad's,and Russ' 950HP even more...at least at the track! Brad,Gary Jacob's(Jake68)chassis dyno is a DynoJet. Rob,the GTX usually 60's in the 1.52-1.56 range. Do you guys agree with the 80-100 hp increase from the head work? I believe,if I can get decent traction..and run 1.49-1.50's,I could hit my 10.8-10.9 goal. BTW..the engine dyno at St. Clair Engine,where I'll be running it,is a Stuska..which is a division of Power Test Inc. Anybody here know how accurate these are? Thanks! Randy
I thought you had a 60' in the 1.6x.... according to Shawn he thinks that dyno is close to real power but is about 10-15 hp short(stingy) which I could care less about 10-15 hp as long as its real ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1288955
08/21/12 05:34 PM
08/21/12 05:34 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
My chassis either works good or I am leaving some power on the table. Since my chassis is basically stock with stock type shocks and stock 45 year old springs I would assume it probly isnt working very good. What converter are you running in the GTX and what gear?
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1288956
08/21/12 05:47 PM
08/21/12 05:47 PM
Posts: 793 Utah
topbrent
Utah
LabRatt, I would suspect you will have plenty of power to get the job done. However, as has been the case in several of your last track outings, chassis prep and traction issues will be the key. http://www.youtube.com/watch?v=gdDtz30-JJ8&feature=channel&list=UL You have plenty of tire, now get the chassis as dialed as the engine. I know that in the past you haven't been too keen on the idea, but "if it were my car"..., I would install Calvert monoleafs/Cal-Tracs and be done with it. For inspiration, ActionAnge has more power and less tire and gets it done nicely with CalTracs.
[Re: topbrent]
#1288957
08/21/12 05:51 PM
08/21/12 05:51 PM
dragram440
bigfork mn
From what I have read on moparts is the cal tracs didnt seem to make much diffence for alot of people on here with mid to high ten secound cars.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1288958
08/21/12 05:58 PM
08/21/12 05:58 PM
Posts: 793 Utah
topbrent
Utah
Are you saying one trip down the track for glory ET testing, or consistent 60ft results over 100's of trips down the track? Sure, some folks can and do get it done really well with SS springs, but the complete Calvert package seems to be able to tame an inconsistent chassis.
CalTracs are generally more tuneable and are usually more consistent.
[Re: topbrent]
#1288959
08/21/12 06:05 PM
08/21/12 06:05 PM
dragram440
bigfork mn
I would certainly be going with the caltracs over the ss springs. I just thought I read on here that most people with mid to high ten secound cars gained little or nothing going to the caltracs over the ss springs.
67' charger 499 RB
10.57 at 127
[Re: STEFF]
#1288960
08/21/12 06:20 PM
08/21/12 06:20 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
it's not the tire, It's that the chassis doesn't work. It's been proven may times, Drag Radials work well, with a good chassis.
FWIW, I agree 100 percent. My pea shooter never hooked very well, never had much weight transfer, etc with ET radials, or slicks. The mild motor in my car right now was blowin the tires off really bad. Made some changes with the UCAs and strut rods and it dead hooks, it even actually transfers weight, etc.
At a local cruise night two weeks ago, a kid in a Cummins pulls up and starts talking trash. Mashed her down, never blipped a tire. Front end came up real fast. He said.."Oh.....Never mind..."
Until I made the changes in the front, it would have blown the tires smooth off.
I'll have a decent motor in the car in a month or so. I "think" with some minor tweaking it will hook fine.. ![](/ubbthreads/images/graemlins/whistling.gif)
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: dragram440]
#1288961
08/21/12 06:36 PM
08/21/12 06:36 PM
RobX4406
I'd disagree with this from my experiences with them. A well sorted out SS spring is more difficult to improve upon. JMO, An 11.00- 123+mph car running 1.6x's in 60' is not a well sorted out car.
Ask Punk/Bryan Sloan about his deal with them. Car ran pretty consistent 1.45-1.47 on SS and ran 1.40-1.42's on cal tracks with ranchos. Car recently went 1.37 with afco's and runs 10.50-10.52 IIRC It was running 10.62-10.65ish on ss springs. Leaves nice, level and straight! As Bryan has said...
"I would say yes to the Caltracs and split monoleafs. They alone wont be the answer to any traction woes however. Its the total combination of carefully chosen parts."
The one car I dealt with that saw no improvement was because the owner didn't want to do what was necessary to make them work. The back was less messed up than the front. ![](/ubbthreads/images/graemlins/hammer.gif)
