4 linking discussion #1288880
08/20/12 10:54 PM
08/20/12 10:54 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
useing you watch dial as reference. Here is the question , with a 116" whl base. if the angle of the top link rear hole is say @11 and the front hole @ 2 , then with the bottom link rear hole @ say 7 and the front hole @4. now useing these angles how do you think this setting would react. and just discuss how you set your top and bottom links and how the different setting would react to different adjustment. thanks
Re: 4 linking discussion [Re: robnbird] #1288881
08/20/12 11:02 PM
08/20/12 11:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Correction.... I read them backwards
Re: 4 linking discussion [Re: robnbird] #1288882
08/20/12 11:13 PM
08/20/12 11:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
useing you watch dial as reference. Here is the question , with a 116" whl base. if the angle of the top link rear hole is say @11 and the front hole @ 2 , then with the bottom link rear hole @ say 7 and the front hole @4. now useing these angles how do you think this setting would react. and just discuss how you set your top and bottom links and how the different setting would react to different adjustment. thanks [/quote
How are you getting 2 on the front top bar and front
bottom at 4... you messed up some numbers
EDIT
For discussion we will say that as a general rule
of thump the bottom bar is the height of the IC and
the top is length... think of it this way... if you
leave the bottom bar along and you lower the top front...
what is occurring... it is shortening the IC... now
if you move the bottom front it raises the IC..
also iif you move the rear bars away from the axle
centerline you gain leverage and will tend to pull
wheel stands easier .... also on the IC you need to
know where the CG of the car is.... that way the IC
will be just behind it to pick up the most weight
Re: 4 linking discussion [Re: robnbird] #1288883
08/20/12 11:18 PM
08/20/12 11:18 PM
Cab_Burge Online work
Cab_Burge  Online Work
I was told to get a big piece of cardboard to map out a 4 link, 3Ft.x5Ft or longer and measure the hieght and center to center distances on the rear end brackets on both sides and the same on the front mounting holes on the frame, chassis and use the ground as a baseline measuring point. Once that was transferred onto the cardboard make lines from the holes on the rear end to each hole on the chassis and shoot for a intercexting point around 7 inches up from the ground and 51 inches from the centers of the holes on the rear end brackets as a staring point an a 3200 Lb car with 500 HP and a automatic with a trans brake that would run in the mid tens to mid elevens in the 1/4 mile. I was told later to make sure the rear end brackets holes, if not directly above the axle center line should be extended to where they would be directly above the center of the rear end housing The car I treid using that on was 1963 or 1964 Nova with a 585 HP SB Chevy with a turbo 400 in it and a early TCI converter, That car as a slug, it struggle to run mid elevens at the old LACR drag strip It didn't spin the tires ever, it had really big set of M/T ET Street tires, maybe 15x33x15 on 14 inch wide rims We move the intercexting points from 48 inches out and 6 inches up to 53 inches out and 5 inches up, no measureable changes in 60 ft. times or reaction times Maybe we didn't make a big enough change, the owner got discourage and gave up trying to make the car better, it was a Pro Street car that he spent a bunch of money and time on to make it real nice, it was really nice It just didn't run as fast as he wanted
Re: 4 linking discussion [Re: MR_P_BODY] #1288884
08/20/12 11:31 PM
08/20/12 11:31 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
well im saying that if you look at my bars back of the car to front. now look at the top bar the read rod end hole would be mounted at 11oclock the front at2 oclock draw a line connecting those point , does that make sense. and the same with the bottom link rear rod end hole at 7 the front of the bottom link rod end hole at 4oclock draw a line . these two angles
Re: 4 linking discussion [Re: Cab_Burge] #1288885
08/20/12 11:34 PM
08/20/12 11:34 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Itersecting point too high. Raise the rear of the bottom bar and lower the front of the of the bottom bar just a bit. Then lower the front of the upper bar. Make a invisible line through those two bars and make where they intersect real close to the bottom of the front bumper. Thats how I would start anyway.
Brian
Re: 4 linking discussion [Re: robnbird] #1288886
08/20/12 11:38 PM
08/20/12 11:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you dont want to do the cardboard thing, you might
want to pick up a 4 link program... there's a few good
ones out there(I think I have them all)... but the bar
length comes into play also
Re: 4 linking discussion [Re: robnbird] #1288887
08/20/12 11:42 PM
08/20/12 11:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
First thing when you talk 4 link... you have you
hole locations and then you have the IC location so
if you say IC thats the intersection of the 2 bars
Re: 4 linking discussion [Re: '72CudaRacer] #1288888
08/20/12 11:48 PM
08/20/12 11:48 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
Brian
Ok im goin to try that. im just not getting the hook I think I should get
Re: 4 linking discussion [Re: robnbird] #1288889
08/20/12 11:58 PM
08/20/12 11:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Lets go a little farther here on this... lets talk
anti squat line... this is part of the 4-link you
wil need to know.... if you take a string and put it
at the bottom of the rear tire at the axle an run
it up to the back of the cam(close enough) that is the
anti squat line... if the IC is above it it will tend
to separate the body from the tire/chassis... if its
below it tends to give the car squat... and if its
on the line it wont do either... so you will need to
watch that also.... so between the CG of the car and
the anti squat line along with the HP you can come
pretty darn close then tweak it from there.. once
you find that happy point you wont need more than
about 4 different settings(all the rest are useless
Also when you talk hole locations they are from the
floor(with the drivers weight in seat)on the front
and most on the rear will be from axle centerline...
just so we're all on the same page
Re: 4 linking discussion [Re: MR_P_BODY] #1288890
08/20/12 11:58 PM
08/20/12 11:58 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
Mr p I have a Baseline suspension article. its at baselineSuspensions.com.....Launching a Drag Car. If you look this up you will see a diagram and my suspension is set up just like this . I just changed to this setting and I have not tried it. I just don't want to get to the track and be all out.
Re: 4 linking discussion [Re: robnbird] #1288891
08/21/12 12:07 AM
08/21/12 12:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Brian
Have you ever had your car on scales... you should
so you can get a idea where the at least mid weight
of the car is... we can tell you all sorts of points
but you would end up working your but off... if you
want a guess I would put it at about where your
trans mount is... so do the cardboard thing to see
what the angles would be
Is it spinning or what
Re: 4 linking discussion [Re: MR_P_BODY] #1288892
08/21/12 12:24 AM
08/21/12 12:24 AM
tn
robnbird Offline OP
robnbird  Offline OP
tn
Brian
I will try the cardboard thing first. i think my IC is aboutthe bottom of the shifter which is mounted on the floor of the trans tunnell.
Re: 4 linking discussion [Re: robnbird] #1288893
08/21/12 12:36 AM
08/21/12 12:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What does it do now.. spin or what
Re: 4 linking discussion [Re: MR_P_BODY] #1288894
08/21/12 01:02 AM
08/21/12 01:02 AM
tn
robnbird Offline OP
robnbird  Offline OP
tn
it spinns more than hooks. 1.36 60ft spinning 15" wids tires 4.88' footbrake. It has a trans brake and I just have not tried it yet. the trans and motor are both new. 5000 stall. coil over set loose .
Re: 4 linking discussion [Re: robnbird] #1288895
08/21/12 01:06 AM
08/21/12 01:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Try it on the TB... and bring up the revs... it should
plant the tire much better
Re: 4 linking discussion [Re: MR_P_BODY] #1288896
08/21/12 10:38 AM
08/21/12 10:38 AM
Out West
408strokerdart Offline
Out West
4-links need to be shocked to work properly. I know of several that just don't hook off the footbrake that work great when hit off the transbrake.
Re: 4 linking discussion [Re: 408strokerdart] #1288897
08/21/12 10:54 AM
08/21/12 10:54 AM
tn
robnbird Offline OP
robnbird  Offline OP
tn
check this out
7344281-4_LINK.pdf (157 downloads)
Re: 4 linking discussion [Re: robnbird] #1288898
08/21/12 01:11 PM
08/21/12 01:11 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
This is a drawing of my cars plot. The center of gravity is found from scaling the car. the height of the center of gravity is one of the points to determine the "anti squat" line. The height of the C/G is projected over the C/L of the front axle.
General rules...
Any intersection points above the anti squat line will make the axle housing separate from the chassis.
Any intersection points below this line will cause the axle to be driven up into the chassis.
Any intersection points behind the actual C/G will work well with lower power/TQ combos, and vice versa.
Re: 4 linking discussion [Re: TRENDZ] #1288899
08/21/12 01:16 PM
08/21/12 01:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
General rules...
Whats your IC length and heights set at..... also
how do you move the screen as you have shown... I
could never figure how to put the screen on a post
Thats 1 of the programs I have also
