rear axle bearings #128860
09/28/08 03:42 AM
09/28/08 03:42 AM
junkyardkid Offline OP
can anyone explain how to remove the rear axle to put bearings in? how do I remove that large bolt? thanks
Re: rear axle bearings [Re: junkyardkid] #128861
09/28/08 03:44 AM
09/28/08 03:44 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
What type vehicle, what year...
Re: rear axle bearings [Re: 1_WILD_RT] #128862
09/28/08 01:59 PM
09/28/08 01:59 PM
sorry, no sleep 45 hrs, women! anyway, 71 scamp, 8 3/4 rear 273 commando 4bbl holley, hi rise eddy, 284 cam, 278 rear gears, dual flows.
thanks
Re: rear axle bearings [Re: junkyardkid] #128863
09/28/08 02:00 PM
09/28/08 02:00 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
There's lots of info on rear axles in the tech archives:
Rear Axle Info
Re: rear axle bearings [Re: Fab64] #128864
09/28/08 02:13 PM
09/28/08 02:13 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Large bolt????
All you do is to remove the wheel, brake drum and the five nuts behind the axle flange and give the axle a good yank it will usually with out too much trouble pop right out. Don't really know what you are doing but you don't want to try to take the bearings off the axle unless you are sure that they are bad. Just wash them out, inspect them and repack them with a good axle bearing grease and rein stall. Replace the inner axle seal for sure though. When you pull the axle out hold the flanged end to the rear of the car so that the splined den rubs on the inner front surface of the housing, when you feel it hit the seal pry back and the seal should pop out on the end of the axle. It may take a couple of tries but it do work and cheaper and simpler than getting tools out to do it. http://www.moparts.org/Tech/Archive/axle/12.html
