Re: Can someone recommend a good electric fuel pump?
[Re: dustergirl340]
#1287100
08/17/12 07:02 PM
08/17/12 07:02 PM
dogdays
[Re: Chris2581]
#1287105
08/18/12 12:25 AM
08/18/12 12:25 AM
Posts: 1,807 North Dakota
Azzkikrcuda
North Dakota
Mallory 4110 pump doesn't need a regulator and would work good.
[Re: Exit1965]
#1287116
08/18/12 03:20 PM
08/18/12 03:20 PM
Challenger 1
Cincinnati, Ohio
Cool, the fuel pump is perfectly located, close and below the sump and behind the fuel cell. And being so close to the outlet helps a bunch and may even allow it to work for you most of the time the way it is. But a non restricted flow of gas to your pump will make the pump last longer and operate quieter. It will shorten the life of the pump at the very least the way it is now.
[Re: frank]
#1287118
08/18/12 04:30 PM
08/18/12 04:30 PM
Challenger 1
Cincinnati, Ohio
I went with an Aeromotive stealth 340. It mounts in the tank.
That's also a very good idea...
