Re: Solid motor mounts 71 Charger
[Re: MIRADAMANia]
#1286288
08/16/12 11:35 AM
08/16/12 11:35 AM
RapidRobert
I'd think both solid mts would be too much vibration. Are your current mts sagged a bit & if not & it's just poor header fitment/stackup of tolerances can you space your mts/eng up slightly?
[Re: RapidRobert]
#1286289
08/16/12 11:48 AM
08/16/12 11:48 AM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
Having both solid mounts is pretty harsh on a street car, been there done that. There are a few options. You could install a solid mount on the drivers(torque) side and leave the rubber on the passenger side. or I would check your current mounts to see if they aren't broken or badly worn and replace if needed, then add one of these. http://www.engine-swaps.com/Pages/ProductsType/TorqueStraps.html#head4Or if you want to do it on the cheap just get a strong small section of chain.
[Re: RapidRobert]
#1286290
08/16/12 12:59 PM
08/16/12 12:59 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I ran a solid mount on the drivers side of my 71 RR for years. I ran the normal rubber pass side mount with the poly trans mount. I never had any problems.
I am truckless..
[Re: MIRADAMANia]
#1286292
08/17/12 09:45 PM
08/17/12 09:45 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I'm running a solid on the driver side of my 360 Barracuda with no trouble. I have read that solid mounts are trouble with high power engines and tires that hook. If the tires hook hard, the solid mount can crack the ears on the block. My car won't hook up that hard so no trouble.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: MIRADAMANia]
#1286293
08/17/12 11:46 PM
08/17/12 11:46 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
A mag mount or polyloc mount on the driverside do a really good job on a street car. Much like solid mounts, running them in pairs is too much vibration. I've got a single mag mount I'm not using. PM me if you're interested. These are normally only sold in pairs.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
