Re: Need pictures of a '71 RR/Sat door regulator and guides [Re: flypaper] #1285427
08/18/12 12:08 AM
08/18/12 12:08 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
Re: Need pictures of a '71 RR/Sat door regulator and guides [Re: flypaper] #1285428
08/18/12 01:41 PM
08/18/12 01:41 PM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
Ok, this is the part I cannot remember. It looks like you said this was on the '72 models??? I have an early build '71 (9-70)I purchased from the original owner in late '77. The doors are/were original to the car, but I took these out. Can you describe or show me (photo) how they bolt/mount back in?
Re: Need pictures of a '71 RR/Sat door regulator and guides [Re: Fasbird] #1285429
08/18/12 01:55 PM
08/18/12 01:55 PM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
And, is there an easy way to determine which is te Right or left regulator from each other? I can see their springs are in opposite directions. Sure I figure it out, but just askin if there is an easy way.
Re: Need pictures of a '71 RR/Sat door regulator and guides [Re: Fasbird] #1285430
08/19/12 01:23 AM
08/19/12 01:23 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
that piece i only found in one of the 6 doors i took apart.
i still have more doors to disassemble..
4 of the doors that didn't have it, i know for sure were 71 doors and they were never taken apart before
i even have the plastic barrier in mint shape i took off
under the door panel.
the door that did have it, had a few differances
besides that part,the guard around the lock was different and something else that escapes me at this moment
thats why i thought it was a 72 piece.
anyway it goes on the top of the window guide
the rubber part catches the leading edge of the interior side of the glass
when the window rolls up.
it is sort of a pita to fit in.
the 2 holes is where it goes
the rubber goes towards the front of the door
the part is sandwiched under these 2 bolts
Re: Need pictures of a '71 RR/Sat door regulator and gu [Re: Fasbird] #1285431
08/19/12 11:12 AM
08/19/12 11:12 AM
None
71rm23 Offline
71rm23  Offline
None
Do you have to seperate the glass from the rest of the mechanism to take out or will everything come out as an assembly?
Re: Need pictures of a '71 RR/Sat door regulator and gu [Re: 71rm23] #1285432
08/19/12 12:02 PM
08/19/12 12:02 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
you have to separate the glass from the rail while it is inside of the door.
that task is the hardest part to getting them apart..
i tried the other way and it was too tight too pull off,
the glass will be scraping up its side..no good.
the worst part of them is the screws/retainer that hold the
rails on to to the glass.
they are usually corroded real bad and hard to get off
a few of the doors i had had bolts put in thier place and
a couple of them i had to even drill out/cut away while they were still inside the door!
the first few pics i showed were taken from
a door that the outer skin was cut away
so you can see a view that you will never see other wise.
that is the way i have that pic with the rails still attached to the window glass.
i know mine are going back together with anti-seize on them
Re: Need pictures of a '71 RR/Sat door regulator and guides [Re: Fasbird] #1285433
08/19/12 12:25 PM
08/19/12 12:25 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i would have to dig them out and look
i kept all my door parts separate.. pass side/drivers side
that way if a latch or a part was different
i wouldn't have to find out the hard way
