Re: 383 Piston choice (KB-162 or KB-400)?
[Re: VITC_GTX]
#1284747
08/14/12 10:52 AM
08/14/12 10:52 AM
Posts: 75,095 A Banana Republic near you.
JohnRR
What is the compression height of a stock 383 2-brl piston? Are the KB 162 and 400 the same compression height?
My stock pistons are .080" in the hole, is that normal for a stock 2-brl 383?
What year is your 383?
A 68-69 383 2 bbl has the same compression height piston as the 4 bbl engine it just has a dish in it , I have not CC'd the dish to see what it is.
I'm going to ask the STUPID question...
Why are you dead set against milling the deck of the block ... it's CROOKED ... or the heads ... NOT FLAT ...
The dome hinders flame travel in Chrysler poor combustion chamber design ... open chamber head .
Use the 162 with a 516 head and a steel shim gasket , problem solved on both comprewssion and quench ...
If anything you will have a higher compression ratio , ASSuMEing that your 383 had 906s or 346s on it .
[Re: VITC_GTX]
#1284749
08/14/12 02:22 PM
08/14/12 02:22 PM
You could mill the head deck surface .030, which would raise CR about a half a point, but the cut would be small enough that you could probably get by without milling the intake surface of the head or the intake manifold.
Should be $100 or so to cut the head deck surface on both heads - at least around here.
[Re: VITC_GTX]
#1284751
08/14/12 02:57 PM
08/14/12 02:57 PM
JohnRR
I have a 383 that will be .030” over and will be used for a daily driver. 650 carb, stock exhaust manifolds and gas friendly cam. Thinking maybe 300-330 horse. Looking at what pistons to get and have narrowed it down to the Keith Black 162’s or 400’s. Seems like most folks go with the 162’s but I’m not sure why since the compression is so low. I do not want to deck the block or mill the heads so what to do???
Facts:
4.280” bore 3.38” stroke 4.5” head gasket bore (estimated) .020” head gasket thickness 90 cc heads (measured- 906) .080” depth to stock piston (measured)
Using Keith Black KB-162 pistons (5cc dish with stock compression distance of 1.908” puts compression at 7.69:1
Using Keith Black KB-400 pistons (6cc dome with stock compression distance of 1.908” puts compression at 8.37:1
The KB-162’s are supposed to be stock replacement pistons though stock pistons don’t have the valve relief so does that mean they have a 0cc dish/dome? If so the compression would have been 7.99:1 with stock pistons.
Why wouldn’t I get the 400’s and have the 8.4:1 compression? Am I missing something?
I just reran these numbers and I get higher compression ratios even with the overestimate bore size of the head gasket , which is actually 4.410 and .021 thick. The KB is .027 in the hole ASSuMEing the block is at factory 9.98 deck.
Flat top is 8.38 with your head gasket or mine
Dome is 9.22, mine is 9.21 ???
I use the calculator at www.Diamondracing.net/tools
Your compression will be higher than original , flip a coin and use which ever you want.
[Re: VITC_GTX]
#1284752
08/14/12 03:08 PM
08/14/12 03:08 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
It's a '71 383 with 906's. I have no dish in my pistons.
I didn't want to deck the block/heads to save money (machine work here is very expensive) and so I didn't have to shave intake manifold. Also, don't want to buy 516 heads. If I could get the engine to come out with stock horsepower and torque I would be fine with it. I was hoping for a re-ring and new bearings after a hone but I have .006"-.008" piston to wall clearance.
I am just trying to find "free" power (pistons are the same cost) if possible and I thought bumping the compression up a little would do just that.
I'm going to try and reuse my factory 69 HP pistons if at all possible. Yes they're heavy but are supposed to be plenty strong for a typical performance street build and have a better compression distance than anything the aftermarket has to offer short of a semi-custom forged piston $$$$. I haven't had a chance to measured my block or piston clearances yet but either way if the old pistons can be used I'm thinking about Swain Coatings for at least the piston skirt and maybe a thermal barrier on top too. Not sure how much money I want to sink into a set of old pistons but they can do a heavy coat to the piston skirt to build up as much as 0.004" to bring clearance back into spec. Just something to consider...
Swain Tech Coating Price Sheet - Link
[Re: CompSyn]
#1284753
08/14/12 03:29 PM
08/14/12 03:29 PM
JohnRR
What happens if the coating wears off ?
How much is it going to cost to coat the pistons ?
[Re: JohnRR]
#1284754
08/14/12 03:59 PM
08/14/12 03:59 PM
CompSyn
Pacific NW USA
Not sure? E-mail sent.
How much is it going to cost to coat the pistons?
$18-to-$24 per piston, skirt only.
[Re: VITC_GTX]
#1284755
08/14/12 04:13 PM
08/14/12 04:13 PM
Posts: 902 Seattle, WA
rss
Seattle, WA
Are they all exactly 0.80 in the hole? Mine varied from about .030 to .050. I'd be surprised if yours are all the same because most blocks weren't square from the factory.
[Re: rss]
#1284756
08/14/12 05:04 PM
08/14/12 05:04 PM
JohnRR
You aren't going to find a block that's skewed .020 end to end, that's a stacking of tolerances in there also, the intake wouldn't bolt on if one were.
It doesn't really matter, he's sticking to a budget.
[Re: JohnRR]
#1284757
08/14/12 05:09 PM
08/14/12 05:09 PM
CompSyn
Pacific NW USA
That's right, the crank throws and factory connecting rods vary some too...
[Re: JohnRR]
#1284758
08/14/12 08:47 PM
08/14/12 08:47 PM
Posts: 4,931 Tri-Cities, Washington
VITC_GTX
Facts:
I used this calculator http://www.csgnetwork.com/compcalc.html
I don't know the deck height of my block, I just used the depth to piston. If my stock piston is .080" in the hole how far with the KB be in the hole?
[Re: JoesMopar]
#1284759
08/14/12 08:52 PM
08/14/12 08:52 PM
Posts: 4,321 Prospect, PA
BSB67
Prospect, PA
.010" cut off the block with Speed Pro 2315's.
What is wrong with this option? Cut the deck to get it to zero deck and run a shim gasket. Down the road, you can put milled Eddys or Stealths on and have additional compression with quench without going back into the motor.
Does anyone kow what these weigh?, you might be able to get away with out balancing it
