1970 Dodge Dart Swinger 340
#1283987
08/12/12 12:50 PM
08/12/12 12:50 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Many know I traded my last project car for a running project car. My '69 Coronet R/T for a Top Banana 340/4-speed/3.91 Dart Swinger. As mentioned, it is running, driving, stopping, and for the most part complete. There are a few appearance, and functional items as well as some performance changes and upgrades I would like to make. Haven't figured out the order of the list yet, but I can hit some of the basics and lay out the list for you and document what I have done and how. Never really started a thread like this because, well, I do a crappy job of taking pictures or documenting anything. Maybe this will help. The list(front to back and as I remember things.): Bumper(s). I had a '70 Dart before that was all primer black including the bumpers. Like the look. The bumpers on this one are very nice, so I'm still up in the air on whether or not I want to do body colored 'glass bumpers or leave 'em chrome. Left inner fender. Right at the core support had a rust hole directly under the battery tray. Not uncommon, but also not terrible. Other than that the inner fenders are very nice. Front suspension. Lots of dry rotted/cracked bushings and boots. Not going exotic, probably poly uppers, rubber lowers, and probably put the stock sway bar back. New torsion bars, tie rod ends, adjusters, strut rods, (maybe lighter) etc. Engine bay. Looks decent. Would like to move the MSD box to somewhere other than the drivers side inner fender. Maybe a new engine/light harness, and clean up all the extra wiring for the MSD. Lots of crimp connections. Engine. First I want to find out what is in it. Would like to add a little bigger cam, ceramic tti headers, paint the thing up a little nicer, replace the abused oil pan(or at least beat it back out), put a set of RHS iron heads on it. Port the intake to the heads, etc. Not gonna mess with the bottom end if I don't have to. All the stroker stuff will be put on my GTS. New bellhousing, the starter locating hole in mine is broken out, different clutch kit and flywheel. Starter is handled as of this weekend. Exhaust. Tti 2.5" all the way back with tips. The one on it now may be original, but the connections to the headers are not done well, and they leak. Transmission. Probably nothing. Speedo pinion leaks, so I need to get a new o-ring for it. Also need the right pinion to make the speedo closer. Windshield. Needs replaced. Has large stone chip and lots of scratches. Dash. Cluster, trim, all could use a restoration. Plans are to pull it when the windshield comes out. Restore it, then put it all back in together. Pedal assembly. Squeak like mad. Pull when dash is out. Carpet, seats, headliner, etc. Plan is to do the interior with the dash, or shortly after. I have the original seat belts and radio to go back in, want to mount a disk player with mp3 input in the glove box. Doors. They both have some issues. Drivers side needs adjusted, wing vent doesn't touch the roof at the top, and nether does the rest of the window. Window isn't secured to the front of the track on the drivers side, ether. Opens and closes fine, but obviously needs adjusted. Locks don't work properly in either door, and key won't go in passenger side very far. Out of order, but wheels and tires. I like the car with Rallys on it. Would like to add 15's in small bolt all around, with a taller tire in the rear and a little taller in the front. The lug nuts all need replaced, they look terrible. Haven't checked, but drivers side to be converted to right hand thread if it hasn't been done already. Front to back, brake and fuel lines replaced with stainless. Fuel level sending unit. Doesn't always work. The tank doesn't seem to leak, but it may get replaced while it is out. Rear end. 3.91's are supposed to be new. So after checking it out, probably just replace seals and go through the rear brakes/hardware. Go wing. I like it. I want to add one, I'm getting opposition from the kids/friends. Shifter/handle. It had a '71-'72(I think) b-body pistol grip in it. It's okay, but I really would like to put a ball shifter in it, and also I think the box itself needs rebuilt/replaced. Body. Will be tackled probably after I get another car on the road. There are some small spots in the passenger floor that need fixed. Trunk floor looks good. Bubbling over rear quarters, in front and back, and a spot in the drivers door that is bubbled. Also on the deck lid. That's all I can think of. I'm going to tackle this project in a way that when I go to replace something, I have everything I need for the job waiting in front of me. No taking it apart and waiting, while not driving it, for parts to come in. Things like the dash will be done over the winter, so I have the time to do it. Lastly, as much of the work as I can do, I will be doing myself. Brakes, suspension, engines, transmissions, wiring, and adjustments I can handle myself. Body, interior, trim, dash cluster, I have never tackled. May send the cluster out. May not. We shall see. So follow along and please, please, PLEASE feel free to correct me, guide me, and help my along the way if you see anything that I could do differently.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: 1970 Dodge Dart Swinger 340
[Re: OhioMopar]
#1283990
08/12/12 03:29 PM
08/12/12 03:29 PM
Well you definitely need help with the pics. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: ]
#1283991
08/12/12 05:11 PM
08/12/12 05:11 PM
OhioMopar
Mt.Gilead, Ohio
Lol. Well, sometimes when I post from my phone they don't show up. Will try to keep all the photographic evidence on my laptop instead of my phone!
[Re: pa340dart]
#1283993
08/14/12 04:26 AM
08/14/12 04:26 AM
OhioMopar
Mt.Gilead, Ohio
I haven't found/looked for the broadcast sheet yet. The plus for keeping it together enough to drive it is the fact that I worked on the car I traded it for for 12 years and never drove it. I will keep this one on the road. I don't want an over the top resto, so I will just do what I can when I can. If I don't have the parts to do the whole job(barring things that I need to send the core in for), I won't take it apart. I missed out on a lot of fun IN a car for a long time, and I am loving this one. I will be starting some of the small stuff tomorrow, will try to light off the thread tomorrow evening. Won't be exciting, but it will keep me moving.
[Re: pa340dart]
#1283994
08/14/12 04:27 AM
08/14/12 04:27 AM
OhioMopar
Mt.Gilead, Ohio
Oh, and I have s '69 GTS that will get started in the next year, too. So I won't be having two cars apart at once! Well, not two including the Swinger!
[Re: 383man]
#1283996
08/14/12 04:53 PM
08/14/12 04:53 PM
OhioMopar
Mt.Gilead, Ohio
Like that car, Ron. Of course it seems anything you have(or had, wasn't it yours first?) is cool. Are the wheel wells stock, and how much rubber did he fit in there?
[Re: OhioMopar]
#1283997
08/14/12 07:39 PM
08/14/12 07:39 PM
OhioMopar
Mt.Gilead, Ohio
Clutch is adjusted. Sorry, no pics. But progress. Also found the pedal 'squeak'. The linkage to the z-bar is bent, it's rubbing the body, burned through the boot. So, new boot, new rod on the parts list. Progress... Now on to the 1/4 window chrome.
[Re: OhioMopar]
#1283998
08/14/12 09:32 PM
08/14/12 09:32 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
I think for a non-tubbed A-body, the largest tire you can fit under there with 0 modifications would be like a 265/50/15 (maybe a 55 with a little rubbing on height). I have a buddy with a 71 Demon and he has 245/60/15 (barely taller than the 265/55/15) and they occasionally rub on larger bumps.
[Re: MuuMuu101]
#1283999
08/15/12 12:58 AM
08/15/12 12:58 AM
moparpollack
Lil Herman
Lil Herman
85086
Biggest tire that doesn't rub is a 245/60/15 on a 15x7.
[Re: OhioMopar]
#1284001
08/15/12 10:07 AM
08/15/12 10:07 AM
moparpollack
Lil Herman
Lil Herman
85086
Backspacing?
4.25 to 4.50
[Re: moparpollack]
#1284002
08/16/12 04:52 AM
08/16/12 04:52 AM
OhioMopar
Mt.Gilead, Ohio
Cool. Thanks. I actually talked to the guy I got it from and he has a couple 15" small bolt wheels. Go figure. $200 doesn't seem too bad. But there may be a reason he didn't put them on...
[Re: 383man]
#1284005
08/16/12 07:37 PM
08/16/12 07:37 PM
OhioMopar
Mt.Gilead, Ohio
Thanks Ron, I appreciate it.
[Re: OhioMopar]
#1284006
08/27/12 07:12 PM
08/27/12 07:12 PM
OhioMopar
Mt.Gilead, Ohio
Here are some pics of the 'to do' list. ![](http://i160.photobucket.com/albums/t181/OhioMopar/Swinger/IMAG0139.jpg) Apparently they liked Edelbrock stuff. ![](http://i160.photobucket.com/albums/t181/OhioMopar/Swinger/IMAG0140.jpg) ![](http://i160.photobucket.com/albums/t181/OhioMopar/Swinger/IMAG0145.jpg) Would like to unload all the Edelbrock stuff and go to the black wrinkle Mopar covers/air cleaner.
