Re: Fabbing up a Single Plane 5.9 Magnum intake
[Re: radar]
#1282819
08/10/12 01:05 PM
08/10/12 01:05 PM
dogdays
If you look at Hogan's work you'll get the picture. IMHO it would be much easier to modify the angle of the bolt holes on an LA single plane, that's the only difference. Or you could hold your nose and buy a Chinese intake for the Mag heads. If you're thinking fuel injection I suggest you visit friend James at www.bigblockranger.com.Also keep in mind that intake manifold manufacturers make their prototypes from fiberglass. R.
[Re: radar]
#1282820
08/10/12 01:39 PM
08/10/12 01:39 PM
Posts: 51 Texas
ChristianCuda
Texas
I believe I can create the taper when creating the runners.
I could buy an intake off ebay for $170. But I have a bunch of 3/8 Aluminum plate and a friend of a friend I could use his welder. So I just have to create the flanges and buy some material for the runners and fab it up figure will cost me less than $50. And it will be cool cause I made it.
[Re: 360view]
#1282822
08/10/12 06:27 PM
08/10/12 06:27 PM
dogdays
I love it! You used one of my secret words..."just". The quote is: "So I just have to" which lights up my board. Long ago I realized that whenever anyone says that word, what it really means is, "Watch out! I'm going to make a very complicated job seem really easy!" I even catch myself doing it and have to stop and think. Most of the time my theory is right.
So, if you really want to do it, go ahead. But if you go way over budget and time before you finish it, if it ever gets finished, I told you so.
It's great when people try something different. I regularly get hosed down for coming up with weird stroker combos, so I can respect the trying. But the goal of doing it for less than $50 is unrealistic.
More than 10 years ago I read this really neat article by a guy who designed and built his own intake for a big Cadillac engine. He had the brilliant idea of increasing the length of the runners to boost low-end torque. Now, why you'd try to boost low end torque on a 500 cubic inch engine is beyond me. But he laid the whole thing out and had the runners crossing under the plenum. The flow path looked like half of a heart shape. The mixture made about a 120 degree turn out of the plenum and I could picture the fuel droplets centrifuging out as the mixture went around the bend. It'd probably work as a dry flow intake, but not so hot with a carb. At the end of the article he had cut all the parts out and "just had to weld them together." I never heard any more about it.
Keep us posted. R.
[Re: 360view]
#1282824
08/11/12 10:33 PM
08/11/12 10:33 PM
Posts: 20,217 Park Forest, IL
slantzilla
Park Forest, IL
The hard part will be keeping it from warping when you weld it up, and getting it to seal up afterwards. You will have to get it machined flat onall mating surfaces after you're done. That will bump up our $50 estimate considerably. There's reasons Hogan intakes cost so much. ![](/ubbthreads/images/graemlins/laugh2.gif) I do understand the "just gotta do it" thing though. ![](/ubbthreads/images/graemlins/thumbs.gif)
