Page 2 of 3 1 2 3
Re: 1970 LAPD Belvedere [Re: savoy64] #1282720
08/11/12 11:36 AM
08/11/12 11:36 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Here's a RK41N1G.....
Are these F codes for heavy duty suspension and or frame? Do they come with every RK police car standard?
N97
Y39
F58
F72
J52
M25
M??
B42
B51
F13
F?38
H51
B51
Re: 1970 LAPD Belvedere [Re: autoxcuda] #1282721
08/11/12 12:18 PM
08/11/12 12:18 PM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
My first car was a 70 Belvedere police unit. RK VIN. The cars with 383 and AC were non HP units painted blue.
My 69 Superbee factory AC car is also a non hp engine painted turquiose and not orange.
If that care was not 3000 miles away it would be in my driveway. And yes they were basically 4 door RR's. I had mine fitted with a GTX front clip and tailights and had the buckets and center console installed.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: 1970 LAPD Belvedere [Re: 69superbee383] #1282722
08/11/12 02:17 PM
08/11/12 02:17 PM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
US Border Patrol car
Re: 1970 LAPD Belvedere [Re: stateline] #1282723
08/11/12 08:57 PM
08/11/12 08:57 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Can't make out the 3 digit engine code at the top
Re: 1970 LAPD Belvedere [Re: JohnRR] #1282724
08/11/12 10:27 PM
08/11/12 10:27 PM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
can you see it in the att. engine is turquoise
Re: 1970 LAPD Belvedere [Re: stateline] #1282725
08/12/12 12:55 AM
08/12/12 12:55 AM
NW
hergfest Offline
hergfest  Offline
NW
I don't think this car was LAPD. All of the LAPD cars I have seen have been green, and the axle code on the tag is 999 due to the rear sway bar. Plus I believe 1970 was the last year for drum brakes, this car has discs. It is still a legit RK41N car though, which is awesome. Would like to see what agency used this car. There was a legit LAPD Belvedere for sale at The Nats.
I used to own a 1970 Plymouth Satellite that was a Seattle PD traffic car, it was a cool car to drive. The Seattle Police Museum has since bought it and restored it back to in service condition. Here is a link to the info on the car, I took the pic in 1999.
http://www.seametropolicemuseum.org/docs/Seattle_Police_Car.pdf
Re: 1970 LAPD Belvedere [Re: hergfest] #1282726
08/12/12 01:32 AM
08/12/12 01:32 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Interesting.
Do the SO numbers on the data tag correspond to any particular agency or special fleet custom buyer. I thought some of the LAPD and CHP cars were built to each agencies custom spec.
Also, could you decode that tag I posted? I don't know what the F codes stand for. I took that tag from a Satelite in the Wilmington, CA Pick A Part "big yard" in about 1989 or so.
Re: 1970 LAPD Belvedere [Re: autoxcuda] #1282727
08/12/12 02:36 AM
08/12/12 02:36 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
F58 - RR C/M reinforcement / welds (rear crossmember??)
F72 - single key package
F13 - HD alternator 60 AMP
F38 - roof reinforcement
Re: 1970 LAPD Belvedere [Re: 6bblgt] #1282728
08/12/12 03:19 AM
08/12/12 03:19 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the 1969 "US BORDER PATROL" Plymouth Belvedere POLICE 2-seat station wagon
does this look correct?
11126 173399 9A162633
+ 900 595 091
**** 26
99 99 L2T T7
RK45 E63 D32 B04 970004
900 = 383 4bbl (330hp) turquoise engine without A/C (STD production # for b-bodies)
595 = 3.23 s/g 11" drums big u-joint (STD production # for b-bodies)
091 = 727 for (non-HP) 383 4bbl #2892091 (STD production # for b-bodies)
99 = "special order paint"
color of the tag looks like FLEET color EF4 "light green"
The transmission number is the same as '69 383 a-bodies
GOT PICS??
Re: 1970 LAPD Belvedere [Re: 6bblgt] #1282729
08/12/12 03:29 AM
08/12/12 03:29 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
can this be moved to "restoration", so it doesn't go "POOF!" if it doesn't get a reply in a few days?
Re: 1970 LAPD Belvedere [Re: 6bblgt] #1282730
08/12/12 04:04 AM
08/12/12 04:04 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks.
I'll try a decode. Please correct if I'm wrong...
N97 - Noise reduction package
Y39 - Special order
H51 - A/C
J52 - Inside hood release
M25 - Wide sill moldings ??odd??
M?? -
GY8 Roof Paint Code: Gold Metallic
U - U.S. Specs
B42 - HD disk drakes ??with 11" rear drums??
B51 - Power brake
GY8 Paint Code: Gold Metallic
L - Low
2 - Vinyl Bench
T3 - Light Tan
GT8 - upper door frame
428 Date Built: 4 / 28 / 1971
SO#: J132N1 ??N?? must be reading wrong
E65 - 383-4 Barrel Roadrunner / Superbee
D32 - H-D 727 TorqueFlite Trans
RK - Plymouth Belvedere/Satellite, Police
41 - 4 Door Sedan
N - 383 300HP 1-4BBL 8 CYL
1 - 1971
G - St. Louis, MO, USA
Re: 1970 LAPD Belvedere [Re: autoxcuda] #1282731
08/12/12 04:16 AM
08/12/12 04:16 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Can you get a clear photo of the whole tag?
Re: 1970 LAPD Belvedere [Re: autoxcuda] #1282732
08/12/12 04:21 AM
08/12/12 04:21 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Y39 - Special order
H51 - A/C
M25 - sill moldings
N41 - dual exhaust
GY8 Roof Paint Code: Gold Leaf Metallic
U - U.S. Specs
B51 - Power brake
GY8 Paint Code: Gold Leaf Metallic
L - Low
2 - Vinyl Bench
T3 - Light Tan
GT8 - upper door frame Paint Code: Tahitian Walnut Metallic
428 SCheduled Production Date: Wednesday 4 / 28 / 1971
VON: vehicle order number J132N1 ??N?? must be reading wrong
E65 - 383-4 Barrel (only 1 4bbl engine was available in B & E-bodies in '71)
D32 - 727 TorqueFlite Trans
RK - Plymouth Belvedere Police
41 - 4 Door Sedan
1 - 1971
M25 is "simply" sill mouldings - it appears the mouldings were possibly STD on the FLEET '71 Plymouth b-bodies.
Re: 1970 LAPD Belvedere [Re: 6bblgt] #1282733
08/12/12 04:58 AM
08/12/12 04:58 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Re: 1970 LAPD Belvedere [Re: 6bblgt] #1282734
08/12/12 04:59 AM
08/12/12 04:59 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
more
Re: 1970 LAPD Belvedere [Re: 6bblgt] #1282735
08/12/12 05:00 AM
08/12/12 05:00 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Y39 - Special order
H51 - A/C
M25 - sill moldings ??odd??
N41 - dual exhaust
U - U.S. Specs
B51 - Power brake
L - Low
2 - Vinyl Bench
T3 - Light Tan
41 - 4 Door Sedan
1 - 1971
Thanks, N41 makes more sense.
Also, did the B42 HD disk come with 11" rear brakes like the T/A-AAR's had?
I can picture the gold Satelite police car in my head. But I can't remember if I got any parts off it. I was looking for 71 383 HP motor to replace the .040 motor in my Challenger R/T.
Got a 71 383 HP short block about that same time out of a 71 Polara "K" code car with like 70K original miles. Shame the car was in the yard, it was a very nice car. I should have just honed the block, but machine shop "convinced" us to rebuilt it. I say "K" code because the car was all white, had cloth insert seats, no light bar holes, Goodyear high miler hoses. The guy who spotted the car thought it was a Fire Chief's car or someone of that nature. It didn't seem to have been used for real Police duty. That guy got the fender tag.
Re: 1970 LAPD Belvedere [Re: 6bblgt] #1282736
08/12/12 05:01 AM
08/12/12 05:01 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
specs.
Re: 1970 LAPD Belvedere [Re: Alaskan_TA] #1282737
08/12/12 05:09 AM
08/12/12 05:09 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yes.
But it's at my parent's house. Maybe later this week.
Re: 1970 LAPD Belvedere [Re: 6bblgt] #1282738
08/12/12 04:25 PM
08/12/12 04:25 PM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
+ 900 595 091
**** 26
99 99 L2T T7
GOT PICS??
Thanks for the decode - the Border Patrol green is a color all its own - the car is a factory F70 red line tire car too It was featured in the Sept 06 MCG
Re: 1970 LAPD Belvedere [Re: stateline] #1282739
08/12/12 11:06 PM
08/12/12 11:06 PM
W
wate Offline
wate  Offline
W
saw the topic and thought I'd add a bit. I own a 70 Plymouth Belvedere 4 dr ex colorado pursuit car. RK41NOA. 383 4 barrel car, has the factory front disc brakes, large rear drums, front sway bar, doesn't look like it ever had a rear sway bar, hemi torsion bars, 80 lb oil pressure dash gauge, white exterior, brown interior, radio delete, non air, nice original rubber mat floor covers, spotlights, SPD 7/4/70. Bought as a project, was sitting around for several years. Has a fender tag, don't have in front of me right now.
Page 2 of 3 1 2 3
