Re: Help me define 360 for dually truck use!!
[Re: CrAzYMoPaRGuY]
#1280417
08/07/12 02:12 AM
08/07/12 02:12 AM
Posts: 6,621 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Not that any of what you have is bad, just go get a cummings complete motor trans, put that in there be done!
What is a Cummings?
You've never heard of The Guess Who???
Kevin
[Re: Blucuda413]
#1280418
08/07/12 11:56 AM
08/07/12 11:56 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Currently have the following items available for use: * 360 block .030 over ex race block. * 360 cast crank std exc shape * Set of good 340 rods * Set of iron ported 202 heads, I've never used * LD340 intake * Stock rocker system * Holley DP 750 carb * Set of solid rollers * Solid Flat tappet cam with approx .600 lift (will have to dig up specs, probably too big for anticipated use) * Good distributor * Good 727 with reverse pattern.
Given the above how much of it would you use for a good torque truck engine??
What items would you purchase to replace above items?
Any input appreciated!!!
I'd reuse the intake, rockers, and dizzy, maybe the heads, conrods and carb,
no need for a race block, I'd go stock block, SCAT 4" crank, KB, ICON, or diamond dished pistons, and a hydaulic like a lunati voodoo 60401.
ideally I'd probably use a demonsizzler t-quad or the new t-quad style carb that demmon (or was it barry grant) just released, and I'd probably use magnum heads.
