Re: Holley or Carter? 1971 HP 383 with A/C
[Re: 72roadrunnergtx]
#1279417
08/17/12 02:06 AM
08/17/12 02:06 AM
Posts: 1,647 IL
71383beep
IL
I will provide further first hand back-up of the existence of factory provided Carter conversion kits for the Holley 4160 applications, performed the conversion many times myself during my time at dealers back then. They were packaged as complete kits, fuel lines, choke springs, any other hardware required, fully covered if under warranty. Installed correctly, appeared completely factory installed. Can’t tell you just how many 4160’s wound up in the trash, considered pure junk then by those who serviced them and many under hood fires were blamed directly on them.
Yeah i read your posts on the bird nest which is why I am wondering if my 4966 AVS was a warranty replacement. I mean everything is where it should be, choke, hose routing, kick down, etc. The only thing it does not have is the ground wire to the dizzy, but the car was converted to the MP electronic ignition sometime in its life. I just was thinking if I could rebuild a 440 AVS for a bit more umpf and it would be a reasonable stock substitute.
i figured the original 4160 holley is next to impossible. Its not the end of the world I am more than happy to live with the carb(s) I have. I just wondered why I had an AVS.
'73 GK6 Challenger Rallye - 340 4-Speed
[Re: sunroofgtx]
#1279420
08/21/12 09:07 PM
08/21/12 09:07 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
LOL LIST 4735..wait until you try and find one! like NON EXISTENT... and big big $$$$$ SOLD 1 for 550.00 a few yrs ago...RARE RARE
Yep, and of the several hundred carbs that have come and gone from my inventory over the years I have seen exactly one (1) single example that's been available for sale, it's customer owned and still sitting here. He wants a ton for it but rightfully so, they are likely one of the rarest Holleys you'll ever have to find if you need one.
[Re: 340cpe]
#1279424
08/22/12 01:20 AM
08/22/12 01:20 AM
Posts: 1,652 Calgary, Alberta Canada
m46rat
Scott how about a holley 4667? I have an early built 71 Bee W/O fresh air, and on the build sheet it has a 48 for carb. Well if I am doing this properly and I believe that I am the 48 is the last two digits of the Part# of the carb which is 3512848. That part# translates to a Holley R4667A. Have you ever seen one or know where I could find one? I could never find one and opted for the Factory Service Manual list# of 6191. Would love to find the right carb as it is a very original car. This Carb question on these 71 383 seems to come up here often. I seem to hear something new everytime that it does!!
What is the SPD of your Bee? I have a super early one of these that Scott restored for me, I think it may be the only one on the planet. It is dated 0540. Holley does not even list this carb in their carb guide book, and they made it! Scott has a bunch of pictures of it that he could post. I am out of town right now so I can<t post any.
[Re: ScottSmith_Harms]
#1279425
08/22/12 01:24 AM
08/22/12 01:24 AM
Posts: 14,471 renton, Washington
ph23vo
renton, Washington
This is my latest list of available customer owned Holley carb cores. These are not mine, prices vary depending on what the owners want for them. I do not sell these cores as is, only as restored units. Some are pretty rough and will require another core carb to scavenge good parts from.
4735 -2190 4668 -2020 Body Only 4367 -0389 4367 -3569 Body Only 4737 -1200 4749-3 2095 Body Only 6191 -1271 4749-3 -1190 6191 -2580 4749-3 -1789 6191 -2780 4749-1 -1082 Top Bail Broken 4668 -2550 4668 -1821 6193 -2730 3918 -2017 4368 -2819 6191 -2580 Top Bail Broken 4366 -0780 4749-2 -3392 4217 -2809 6169 -3170 Body Only 4749-3 -0700 4368 -2679 3918 -2357 4166 -3148 1850-2 -3028 4367 -2619 3667-1 963 Part# 2843151 4749 -0224 4367 -3539
i have:
LIST 6191 x 2 [2260 & 2280]
LIST 6193 [2370]
LIST 4737 [0120]
71 4 speed idle solenoid also almost NOS
#1279428
08/22/12 08:57 AM
08/22/12 08:57 AM
Posts: 12,132 Cleveland
sunroofgtx
Cleveland
Watch it Scott. The black Suburbans are rolling your way !!.. Nice
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
