Re: 1968 plymouth wont idle, msd ignition,rebuilt carb
[Re: mopardiebold]
#1278996
08/04/12 10:41 AM
08/04/12 10:41 AM
RapidRobert
I'm thinking MSD wants full 12V no ballast
[Re: mopardiebold]
#1278999
08/04/12 02:48 PM
08/04/12 02:48 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
this car hasnt run in 10 years i got it and put new gas tank, sending unit, lines,rebuilt carb
Off topic, but I just wanted to mention, after all that time you might wanna redo, or at least flush the brakes as well. Hope you get it sorted soon and it turns out to be simple.
I have mechanical Aptitude. I can screw up anything.
[Re: sunroofgtx]
#1279000
08/04/12 08:40 PM
08/04/12 08:40 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Look here
http://www.bing.com/images/search?q=msd+...amp;FORM=IQFRBA
but the coil may not. i would definately investegate that wiring snake nest though. what does your coil spark look like when cranking the engine, good and strong? can you watch a spark on a cylinder (pull a plug wire at the plug and put a screw or bolt in the wire and hold it about 1/4 inch from a ground) and see if the spark is still strong while lowering your rpms? are you sure this isn't a timing issue?
[Re: mikemee1331]
#1279002
08/04/12 09:06 PM
08/04/12 09:06 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
also, this sounds more like the carb mixture screws than much of anything else. i know you had the carb rebuilt but the mixture couldn't have been set without it being on a running engine.
Maybe it's that dastardly initial timing issue, not enough of it.
[Re: RobX4406]
#1279003
08/04/12 09:22 PM
08/04/12 09:22 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Im running MSD, stock coil and no bassast with no problems for over 10 years. I believe theres a carb problem..
I am truckless..
