Hi folks
I was about to repair the turn signal switch of my Challenger and started to remove the crush can, but noticed that the two threads where the steering wheel puller is attached were badly damaged and can't hold at all the bolts of the puller.
Tried to use Loctite threadlocker, but even it could not hold the bolts in place to pull the can out of the steering shaft...
I assume I am not the first who has run into a same kind of problem when trying to pull the crush can.
Good advice is highly appreciated, how should I now remove the crush can without damaging it severly?
