who sells a turn signal wiring assemble for a 69 RR? #1278604
08/02/12 10:53 PM
08/02/12 10:53 PM
Hermiston Oregon
mopar_leaner Offline OP
Hermiston Oregon
Im working on a 1969 RR and have no brake lights, I have traced the problem to the wiring harness that up through the column to the turn signal switch.
Does anyone know where I can buy the whole unit new to replace this, other than Year One?
thank you Moparts!!!
( it takes a Mopar, to beat a Mopar!
email me at moparleaner@gmail.com )
Re: who sells a turn signal wiring assemble for a 69 RR? [Re: mopar_leaner] #1278605
08/02/12 11:24 PM
08/02/12 11:24 PM
See what that certain auction site that we dont mention has to offer
Re: who sells a turn signal wiring assemble for a 69 RR? [Re: RapidRobert] #1278606
08/02/12 11:32 PM
08/02/12 11:32 PM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
I just got a reproduction on ebay from Vans for a 70. It arrived with a frayed wire and a severely twisted wire and in a box marked tested. It did test out ok and I fixed the wires on it. I would watch buying from Vans.
Re: who sells a turn signal wiring assemble for a 69 RR? [Re: mopar_leaner] #1278607
08/03/12 12:04 AM
08/03/12 12:04 AM
ontario canada
426lloyd Offline
426lloyd  Offline
ontario canada
got one from herb's no problems with it.
Re: who sells a turn signal wiring assemble for a 69 RR? [Re: Rollin Hand] #1278608
08/03/12 12:04 AM
08/03/12 12:04 AM
Hermiston Oregon
Hermiston Oregon
thank you so much!!!
Re: who sells a turn signal wiring assemble for a 69 RR? [Re: mopar_leaner] #1278609
08/03/12 12:30 AM
08/03/12 12:30 AM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
If anyone needs a 70 and up B body and others switch do a search on rockauto under 73 Chrysler New Yorker for #SM111 for $26 this is the same switch Vans and others sell for $50 plus dollars for B bodies etc.
Re: who sells a turn signal wiring assemble for a 69 RR? [Re: Rollin Hand] #1278610
08/03/12 01:45 AM
08/03/12 01:45 AM
Hermiston Oregon
Hermiston Oregon
nice, but the sm111 fits the newer cars with the hazard switch built in
Re: who sells a turn signal wiring assemble for a 69 RR? [Re: mopar_leaner] #1278611
08/03/12 11:41 AM
08/03/12 11:41 AM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
Go to www.shee-mar.com and see if sm106 is what you need. Rockauto shows that number for $73
Re: who sells a turn signal wiring assemble for a 69 RR? [Re: Rollin Hand] #1278612
08/03/12 12:04 PM
08/03/12 12:04 PM
GA
roadrunninMark Offline
GA
I ordered one from Autozone for a 71 barracuda. It was about 10 bucks, and it doesn't have the right feel or sound to it. It is a Dorman part. I will probably change it out to a better one later. I think Classic Industries has them too.
Ya, here you go: https://www.classicindustries.com/search?q=turn%20signal&y=1969&m=mopar&sm=70
Re: who sells a turn signal wiring assemble for a 69 RR? [Re: roadrunninMark] #1278613
08/03/12 12:21 PM
08/03/12 12:21 PM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
The $10 autozone part is just the cancelling cam not the whole switch.
