Re: transmissions date coded???
[Re: 6bblgt]
#1277376
08/01/12 06:57 PM
08/01/12 06:57 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
FWIW, here are your tags mixed in with similar sequence numbers and SPDs. The 426 cars are A12 cars.
(Model-Body style-SPD-Sequence number-VIN)
WK 41 416 264849 259506 RM 23 506 265327 267355 WM 23 426 265355 265982 RM 21 426 265721 263145 WM 23 426 266689 261837 RM 21 426 267631 270343 WM 23 426 267642 270631 WS 23 507 267787 269749 RM 23 501 267813 264119 RM 21 426 267851 264574 RP 23 506 267882 267636 RS 23 502 268503 266319 RM 23 426 268660 270976 RM 23 502 269567 265199 WM 21 426 270705 271406 WM 23 426 270719 271395 WM 23 512 271128 272164
[Re: 69CoronetRT]
#1277377
08/02/12 01:41 AM
08/02/12 01:41 AM
Posts: 1,559 Oh
His and Her 69's
Oh
Thanks so far for the info guys. I will have to look at my fender tag and see what the sequence # is. David
EDIT, Dan and Doug my sequence # is 266813 Does that tell you anything different??? Thanks Guys for the Info.
[Re: His and Her 69's]
#1277378
08/02/12 12:45 PM
08/02/12 12:45 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
So I guess the real question is do you want to find the SPD or the actual date. It would appear that your car was built 1147 units early.
Doug and Dan; May 4th and 5th were a Saturday and Sunday. Any idea what the plants production days/hours were for the weekends?
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1277379
08/02/12 02:40 PM
08/02/12 02:40 PM
69CoronetRT
Harlan, Iowa
I don't. I do know that I have six to seven consecutive days of SPDs at the 1969 STL plant so there was (presumably) work on Saturdays and Sundays.
I would think weekend production would be 'seasonal' depending on the time of year, total sales volume, plant production capability, if one plant had to pick up production because another plant was down and things like that.
A nice thing about a large plant data base is it gives you a better idea as to production volume on a per week or per day basis.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 69CoronetRT]
#1277380
08/02/12 03:21 PM
08/02/12 03:21 PM
DPelletier
What I was thinking is that if the SPD was 506 (Monday) and the car was 1147 early then depending whether they worked that weekend makes it hard to say if the actual production date was thurs/friday or on the weekend. My car's VIN is WM23V0A185788, the sequence number is 185226 which makes it 562 cars early. The SPD is C18 which was a Thursday so my car was probably built on Wednesday, December 17th 1969. fun stuff. Dave
1974 'Cuda
#1277382
08/03/12 10:59 AM
08/03/12 10:59 AM
Posts: 5,124 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
With Automotive production there are many variables that changes the actual date that is considered a cars build date. I have found that every year or type of car had its screw ups after the fender tag and broadcast sheet were made. With E Bodies I believe it has to do with the options that were ordered and how available these option were and how well the production plant kept track of the parts needed to for the build. I thave found at the end of the production year parts were not tracked as well as during the year. Maybe this is because of holidays or students or new employees in May June and July. I would think that an A12 build might have similiar problems with attaining the special parts it needed.
Now any of you guys have any theories on why A12 Road Runner production stopped much earlier than A12 SuperBee Production or does your research tell you something different.I judge this be looking at VIN numbers and Super Bees being much later. The only real difference in the cars from normal production car is the hood from Runner to Super Bee.
1971 HEMI E BODY REGISTRY
