Recommend me a tire size!
#1276750
07/30/12 05:53 PM
07/30/12 05:53 PM
Posts: 4,064 Boca Raton, Florida
jpilone
Boca Raton, Florida
Using 15x7 cop car rims on my car (using '70 Rallye centers and trim rings).
I was thinking 245/60/15 fronts and 255/60/15 rears.
The car will be about 1.5" lower than stock.
Anyone?
-Jarrod Pilone '70 Plymouth RR Convertible with amazing custom paint(Tribute/Recreation/Whateveryouwannacallit) My Project Thread
Re: Recommend me a tire size!
[Re: jpilone]
#1276751
07/30/12 06:22 PM
07/30/12 06:22 PM
moparpollack
Lil Herman
Lil Herman
85086
Way to small try 225/70/15 front and 275/60/15 rear. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: jpilone]
#1276754
07/30/12 08:09 PM
07/30/12 08:09 PM
moparpollack
Lil Herman
Lil Herman
85086
Try 255/70/15 they are decent also.
[Re: jpilone]
#1276757
07/31/12 12:45 AM
07/31/12 12:45 AM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
Go 225 or 235/70 on the front. I just mounted up some 245/60's on my 69 GTX front and not real keen with it. For the rear, go for the 275/60's.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: jpilone]
#1276760
07/31/12 12:40 PM
07/31/12 12:40 PM
Posts: 5,665 Detroit area
6PAX
Detroit area
I once tried mounting a 235-70-15 on a 15x7 rally on my 70 Road Runner and it was too big in diameter and rubbed the fender at the front of the wheel opening. Do you think a 235-70-15 would fit without rubbing if maybe a 6" wide wheel or a 15x7 wheel with different rear backspacing than that of a factory rally were used?
[Re: DaytonaTurbo]
#1276761
07/31/12 03:32 PM
07/31/12 03:32 PM
Posts: 4,179 California
mickm
California
Would a 275/60 even fit properly on a 10" rim? 10" is a wide rim and a 275/60 isn't that wide of a tire. I've run 275/60's on a 7" rim for years. No problems, no weird tread wear, get a clean patch of rubber when I
i run them on a 10" rim, no problems. only issue is that i can't get a 295 under there, as the 10" rim balloons out the sidewall. it doesn't look bad, and isn't noticeable, but it is out far enough on the 10" rim that a 295 won't go.
i recently ran into a 70 with 275/60's on an 8" rim, and the difference in room under there was amazing. i'm going to go with a 295/55 on an 8" rim, and that should get me the extra tire under there.
[Re: mickm]
#1276762
07/31/12 10:39 PM
07/31/12 10:39 PM
jpilone
Boca Raton, Florida
what about a 255/60/15 front and 275/60/15 rear? That's about a 27.5" front and near 28" rear I think...
