Re: Newly built motor won't budge. HELP!!!
[Re: PAINT IT BLACK]
#1276345
07/30/12 12:42 AM
07/30/12 12:42 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
What damper was on the engine when it was on the dyno? Is the flywheel/clutch/pressure plate all new? Any chance the flywheel binds in the bellhousing? How about the bolts mounting the crank pulley?
[Re: buildanother]
#1276349
07/30/12 01:09 AM
07/30/12 01:09 AM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
the balancer can't really hold it, so I'd bet on flywheel bolts also. There is not alot of extra room there.
This is what I'm thinking now... the replacement of the bolts didn't occur to me until I started this thread, but the reason they were replaced is the builder lost the originals. I bet this is the reason. I'll dig in tomorrow.
[Re: 1_WILD_RT]
#1276350
07/30/12 01:43 AM
07/30/12 01:43 AM
PAINT IT BLACK
Houston Texas
Thinking back... I think this damper was actually used in this last build, so that's not it (though I did add a different crank pulley. so I'll recheck that before I do anything).
Flywheel is the same, but the clutch/plate are new to this car.... under 400 miles, like new - leftover from another one of my cars. Flywheel clears the bell housing fine.
Thanks y'all!
#1276351
07/30/12 02:07 AM
07/30/12 02:07 AM
Posts: 10,166 A Red State
SNK-EYZ
A Red State
Make sure that the crank pulley bolts aren't too long and hitting the timing cover at the front seal.
I way going through my timing covers looking for one to clean up when I saw one the looked like the crank pulley bolts were tightened in to it (that or puller bolts were twisted into it).
Definitely check the flywheel bolts.
[Re: SNK-EYZ]
#1276352
07/30/12 02:26 AM
07/30/12 02:26 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Typically the starter or a socket & breaker bar would cause long bolts attaching the pulley to chew up the timing cover but the engine would still turn & start/run..... So i agree probably the flywheel bolts are to long... You should be able to see that fairly well with the clutch cover removed you can see the crank flange & the rear main bearing/seal retainer cap...
[Re: 1_WILD_RT]
#1276353
07/30/12 04:36 AM
07/30/12 04:36 AM
PAINT IT BLACK
Houston Texas
Well, I can see the flange/bolts with the inspection cover removed and it doesn't seem the bolts are too long. They just barely make it through the flange.
The crank pulley bolts are short, so that can't be it either. Again, the trans is unbolted and pulled back to where the splines are not in the clutch anymore and this has been isolated to the motor. I don't want to pull the trans out, because it will require the removal of my AAR exhaust (pain in the butt), as well as the driveshaft loop, which is bolted to the body of the car.... just a bunch of reinstall headaches which seem unnecessary.
I can't really remember clearly, its been so long, but I may have removed the damper for painting... Would it be possible for me to have overtightened the damper to the point where it could be causing this? Long shot, but what about the distributor gear? Could I have jammed that with a careless install? If so, would it jam the motor up like this?
Other than that, I don't see what could possibly be causing this. It is REALLY stuck!
#1276354
07/30/12 04:42 AM
07/30/12 04:42 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
The damper shouldn't be able to lock the engine... Well the part that goes through the cover & the bolt going into the crank shouldn't... If anything is contacting the damper outside the cover it's possible.... Good luck, this sucks..
#1276355
07/30/12 06:44 AM
07/30/12 06:44 AM
Posts: 1,357 central Florida
VL21
central Florida
OK, perhaps this is a long shot, but is it possible the pressure plate cover is against the bell housing? Taller, installed before the bell? I did this once long ago, but on something else...using a non stock set up...? ![](/ubbthreads/images/graemlins/shruggy.gif)
It takes gasoline to interest me.
#1276357
07/30/12 09:37 AM
07/30/12 09:37 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
Dampner being too tight wouldn't cause this , I'd start pulling off things that may cause the issue , pulley bolts , pop out the distributor , I had a pontiac iron duke that the roll pin holding the drive gear on can out and lockup up the cam , it sheared the key off that held the cam gear in place , if the pin that holds the drive gear to the oil pump shaft spit out for some reason it could lock up the motor.
![](/ubbthreads/images/graemlins/3_2_116.gif)
[Re: Challenger 1]
#1276361
07/30/12 11:53 AM
07/30/12 11:53 AM
PAINT IT BLACK
Houston Texas
Pull the spark plugs...
Called the builder and this is what he said. I can fathom that water might have gotten behind the tape I used when pressure washing before painting.... I bet this works.
He said hammering the trans in wouldn't likely hurt anything.
