Re: Anyone have a 325-350 hp combo for a 318 build?
[Re: drifter]
#1275373
07/28/12 03:53 PM
07/28/12 03:53 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
If you are dead set on a 318, Id start with a Magnum engine. Much better heads that will support that kind of power without near the work or, any at all for that matter. They seal up better too, meaning less oil leaks. Find one in the salvage yard and re ring and bearing it and basically all you should have to do is slide in a small 268 to 274ish duration cam, edelbrock intake, your 650 carb and a good set of headers and you should be right on the money.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: drifter]
#1275374
07/28/12 04:02 PM
07/28/12 04:02 PM
Posts: 2,177 ill
dennismopar73
ill
Nothing wrong with building a 318, they will run ! find some 587 heads, or x ,, get good cam choice,intake, good vert, ?430 gears? 318, un-respected by racers, just because of 2 digits
[Re: drifter]
#1275375
07/28/12 04:22 PM
07/28/12 04:22 PM
Posts: 644 Owego, NY
JBurch
Owego, NY
KB 167's, zero deck, 360 heads cut down to around 60cc, 2.02/1.6 valves, thin head gasket, Edelbrock Performer, or Air gap (though a Performer will do just fine), 600 to 750 cfm carb, old school cam MP 284/.484, or new school with similar lift and duration numbers.
[Re: JBurch]
#1275376
07/29/12 07:14 AM
07/29/12 07:14 AM
Posts: 2,917 A shed in England
Tig
A shed in England
Fan of the 318 here Hot rod did an article on 318 hop ups many years ago, the old MP engine book has some tips and recipes for the 318 too. I did a search to see if I could find them out there but I couldn't. I did find these however, if you are after a little more of course: http://www.dippy.org/forum2/index.php?topic=242.0www.moparmusclemagazine.com/techarticles/mopp_0409_318_engine_build/index.html HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: drifter]
#1275377
07/29/12 07:44 AM
07/29/12 07:44 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
318 block with KB 167 pistons 360 rods 360 heads with 1.88 valves 273 adjustable rockers Comp Magnum S282S retro grind solid cam (236 @ .50, .495)
Twin 2.5 system, 1 5/8 primary Header
Crane Hi-6 or MSD ECU
Clutch or electric fan
LD340 or Air Gap intake
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
[Re: dennismopar73]
#1275379
07/30/12 08:19 AM
07/30/12 08:19 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
magnum 318, with an eddie RPM air gap, headers, hughes #1110 springs and their retainers, and regrinding the factory roller cam either by bulletcams.com or pick up the hughes HER1418AL
should be an honest 330+ HP
