727 noise problem???
#1274883
07/27/12 12:17 PM
07/27/12 12:17 PM
Posts: 310 western Ky
CraigS
western Ky
Hey everyone, I have a situation with my racecar,I have a LOUD noise on deceleration only, in my 727??? maybe.I say maybe cause the trans guy I had highly recomended tells me there is nothing in the trans that can make this noise.Its a loud gear roar type sound, at the end of the track after i let off the gas,its so loud its heard over the open headers.It seems to me it always made this noise ,just 100 decibels less before.I t works great down the track ,shifts good and tight,but at the end ,when i am decelerating after the pass it makes the noise.After it slows down to a coast ,it stops makin the noise,but even as i am coasting thrue the pits with the engine off,in nuetral,if i slow down with the brakes it makes the noise again.The trans guy says its my rearend.The rearend is a $2500 moser dana60 2years old with only 200? passes on it,and i cant believe it could be that!!!Its a pro gear 4.56 ,spool,35 spline axles,aluminum "preload on the caps" rear cover.top of the line .So my question is ,What do you fellows think? I know its impossible to diagnose a problem over the internet,but any ideas???
Re: 727 noise problem???
[Re: CraigS]
#1274884
07/27/12 12:34 PM
07/27/12 12:34 PM
Posts: 164 Savannah, GA
mopar400
Savannah, GA
A pinion bearing in the rear end could cause that noise. If its the outer bearing it would be louder when letting off the gas. The way the gears are cut the force on acceleration tries to push the pinion toward the front of the car and loads the inner bearing. Letting off the gas loads the outer bearing because the pinion is trying to get sucked into the diff. housing. I've also had a roar/ vibration when letting off the gas in the 1/4 mile because i had too much pinion angle. The car was smooth under load but when the front of the pinion dropped on decel. it would vibrate/ roar. Kevin
Also I would check to make sure the pinion nut has not come loose
1965 Fury II
1970 Challenger 440, 509 cam, 11:1 w/ 452 iron heads, 6.99 1/8, 11.29@ 120mph 1/4
(1999 Magnolia Drag strip track champion)
1992 Jeep XJ Crawler
[Re: CraigS]
#1274887
07/27/12 12:46 PM
07/27/12 12:46 PM
mopar400
Savannah, GA
Ok,The nut is tight,I am draining the fluid out of the rear right now,to get the cover off,what do i need to look for?there does not seem to be any metal chips/shavings in the oil.I did change the gear oil over the winter,and changed to synthetic.Yhe noise was not there last year at the end of the season....then on the first pass this year its there...how can it happen so fast???
Does it make the noise only with the brakes applied or both letting off the gas and w/ brakes applied? A bad bearing should have some shining metal flakes in the housing. Taking the yoke off and pulling the front bearing would be the only way to really inspect for roller damage.
1965 Fury II
[Re: CraigS]
#1274892
07/28/12 07:27 PM
07/28/12 07:27 PM
Posts: 7,506 Az
Crizila
Az
Still believe it's in the diff. Did you filter the drained oil to look for stuff? How does the gear pattern look? Lots of pinion angle could do it also, but you would get a rumble / vibration with the noise. Are you coasting down in gear or neutral?
Fastest 300
[Re: Dads426]
#1274897
08/23/12 09:53 PM
08/23/12 09:53 PM
CraigS
western Ky
Sorry fellas but after a couple days of no hits ,i stopped paying attention to this thread,I still have not taken it back to the track .I have to put in a new set of lifters 1st,but thats another story.The rear end is so smooth to turn by hand,it just cant be the problem.I did hold the yoke when i tested the tightness of the nut,its good.The u-joints felt good no play but were a little stiff.They dont have a grease fitting,but i put some more grease in the caps before reinstalling them.The noise really sounds like a gear or bushing/bearing rather than a vibration.....i am gonna run it up and down the road after lifter install and get my partner to listen....maybe we can find out what or where.And the age of the springs,they are at least 15 years old ,mopar superstock springs for 2800 lb car ,i think 002, and003"s????They seem fine the car still sits up high and they work great ,no wheelhop or any other traction problems.I will get back on here when i find something out,but life is gettin in the way right now,I am really broke.
