Re: car stops running after key is released
[Re: btomasko]
#1274357
07/26/12 11:54 AM
07/26/12 11:54 AM
RapidRobert
dies immediately after releasing the key or after a bit? Recent problem? always done it? Any part changes/adjustments right BEFORE the problem started
[Re: Andrewh]
#1274360
07/26/12 12:05 PM
07/26/12 12:05 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Have you done an electronic ignition conversion, I am guessing yes since you mention the module. Try looking at the pickup coil inside the distributor. This seems to have the signs of a failed one.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: btomasko]
#1274365
07/26/12 03:21 PM
07/26/12 03:21 PM
RapidRobert
My eddy 1406 would stall for no reason at idle regularly & it was dirt in the idle circuit. A 2 second blast of starting fluid into each idle mixture screw hole took care of it (repeated twice in a weeks' time). But from your descrip you're thinking it is an electrical prob?. I would clean the bulkhead brass terminals for a start
[Re: RapidRobert]
#1274366
07/26/12 03:29 PM
07/26/12 03:29 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Throw the ORANGE ignition box in the trash and replace it with 1 from your local parts house...
I am truckless..
