car stops running after key is released #1274356
07/26/12 11:46 AM
07/26/12 11:46 AM
btomasko Offline OP
btomasko  Offline OP
The following items have be replaced to no avail on fixing the problem,ignition switch,ballast restor and mogle,it starts but does not stay running plenty of spark and fuel,coil tests, good anyone have any ideas help 1968 roadrunner. thanks
Re: car stops running after key is released [Re: btomasko] #1274357
07/26/12 11:54 AM
07/26/12 11:54 AM
dies immediately after releasing the key or after a bit? Recent problem? always done it? Any part changes/adjustments right BEFORE the problem started
Re: car stops running after key is released [Re: btomasko] #1274358
07/26/12 11:55 AM
07/26/12 11:55 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
if you've changed all that stuff with known good parts the issue has to be in the wiring between the switch and the ballast, when it makes the transition between start and run. it's 2 different circuits.
Re: car stops running after key is released [Re: btomasko] #1274359
07/26/12 11:58 AM
07/26/12 11:58 AM
Andrewh Online content
Andrewh  Online Content
so now you eliminated the ballast which is normally what this would be, unless it is bad again, which you check for continuity.
second you eliminated the ignition switch, but again, could still be bad.
the next thing to check for voltage at the ballast, then back track to the bulkhead connector till you find your missing power.
Re: car stops running after key is released [Re: Andrewh] #1274360
07/26/12 12:05 PM
07/26/12 12:05 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Have you done an electronic ignition conversion, I am guessing yes since you mention the module.
Try looking at the pickup coil inside the distributor. This seems to have the signs of a failed one.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: car stops running after key is released [Re: hp383] #1274361
07/26/12 12:19 PM
07/26/12 12:19 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
If this is a car with the ign swithc mounted on the column, actuated by a rod from the lock cyl, that switch could be not adjusted/located properly.
Re: car stops running after key is released [Re: Fury Fan] #1274362
07/26/12 01:55 PM
07/26/12 01:55 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Unless the column was changed this is a dash switch.
I agree with those saying to chase that wire back to the bulkhead.
Might just need a good cleaning.
Hope so.
I have mechanical Aptitude.
I can screw up anything.
Re: car stops running after key is released [Re: RapidRobert] #1274363
07/26/12 02:50 PM
07/26/12 02:50 PM
btomasko Offline OP
btomasko  Offline OP
Robert,I just was going to take the car to a show when this problem occured,no changes were made before hand. I even checked the fuel pump
thanks
Re: car stops running after key is released [Re: btomasko] #1274364
07/26/12 03:19 PM
07/26/12 03:19 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
If its not the pickup coil, you can also check the grounds to the ignition module.
Re: car stops running after key is released [Re: btomasko] #1274365
07/26/12 03:21 PM
07/26/12 03:21 PM
My eddy 1406 would stall for no reason at idle regularly & it was dirt in the idle circuit. A 2 second blast of starting fluid into each idle mixture screw hole took care of it (repeated twice in a weeks' time). But from your descrip you're thinking it is an electrical prob?. I would clean the bulkhead brass terminals for a start
Re: car stops running after key is released [Re: RapidRobert] #1274366
07/26/12 03:29 PM
07/26/12 03:29 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Throw the ORANGE ignition box in the trash and replace it with 1 from your local parts house...
I am truckless..
Re: car stops running after key is released [Re: 340SHORTY] #1274367
07/26/12 08:01 PM
07/26/12 08:01 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
my car does the exact same thing.it only happens every once in a while.if i unplug and replug the ballast she will start.i know this sounds odd,but it works.someone told me its a bad wire on the ballast but im yet to find it.
Re: car stops running after key is released [Re: mcmopars] #1274368
07/26/12 08:32 PM
07/26/12 08:32 PM
Detroit, MI
RawnDart Offline
RawnDart  Offline
Detroit, MI
The problem is likely in the connector from the ignition switch to the bulkhead.
Mine would occasionally do that, and when I looked deeper into the problem, I found this:
