Regular methanol to M5 methanol? (Results)
#1273837
07/25/12 02:32 PM
07/25/12 02:32 PM
Posts: 1,073 oregon
greendart408
oregon
Does anyone have a real world numbers of what someone might see by running it for gains? I know what is claimed from vp but would like someones back to back comparison?? Been thinking about trying some. Would have to richen a small amount to benefit I am sure. BTW this is with injection.
Re: Regular methanol to M5 methanol?
[Re: greendart408]
#1273838
07/25/12 05:35 PM
07/25/12 05:35 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I was told when going from M1-M5 to go 6-8 sizes bigger on the return pill(I run injection also),which would lean it out.They say M5 is oxygenated fuel and takes less fuel than M1. We will have my engine on the dyno in the next couple of weeks and if nothing happens I plan to do a back-back test M1 vs M5.
I have heard of Big gains,No gains....the dyno will show the gains if they are any to be had. Lets all share ideas and information and I will try them and post some real Dyno numbers from them,and if I see a advantage to running the M5 on the dyno I will do a back-back test at the track and get some ET slips.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1273839
07/25/12 05:59 PM
07/25/12 05:59 PM
Posts: 1,073 oregon
greendart408
oregon
Please do, I am going to try some.
[Re: DavidDean]
#1273841
07/26/12 01:43 AM
07/26/12 01:43 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Here is a copy and paste from VP. Read the M3 then look at the 5.
VP offers several types of methanol racing fuels, each of which offers top quality for applications ranging from drag racing, circle track and road racing to off road and powerboats. Among the most important features of VP’s methanol products is consistency in production and pack- aging. Much of the cheaper methanol on the market is reclaimed from industrial processes and far more likely to contain contaminants. VP doesn’t cut corners or ‘reclaim’ methanol. While that leads to slightly higher prices, our customers can trust our product and have much greater assurance they won’t have to deal with “bad fuel” issues.
Why offer three types of methanol? VP has always emphasized giving our customers options. We try to make sure we always have the absolute best performing option available, making the most power possible given an application’s parameters. But there are other considerations—budget, fuel rules, or environment for example—that sometimes dictate the selection of a fuel other than one that makes the most power.
M1TM - M1 is the best straight methanol on the market. No frills, but consistently 99.85+% pure and always packaged in lined drums, as are all VP fuels. That means no contaminants and peace of mind from knowing you don’t have to deal with fuel issues. When fuel rules require the use of straight methanol with no additives, M1 is the best option.
M3TM - M3 contains combustion and lubrication additives that improve vaporization and increase burning speed. These factors, combined with a better seal of the rings due to the lubrication additive, make substantially more power than straight methanol—up to a 50 Hp gain in a 1030 Hp engine. The improvement in throttle response is also significant—up to a 5% increase in torque across a wider rpm range. On-track results indicate a .02-.03 improvement in ET in the 1/8 mile. The improved combustion also helps the thermal efficiency of the air/fuel mixture. This expands the range of ignition, contributes to better ‘startability’ and more consistency run to run, while lowering the exhaust temperature 40-100°. Not only will M3’s improved combustion make more power and offer better protection against detonation, it also inhibits the noxious fumes you typically get with standard methanol, so it’s much easier on your eyes and nose. A somewhat unexpected benefit of M3 is a 30% decrease in fuel consumption. That means if you typically use 40 gallons over a race weekend, you’ll only need about 25-30 gallons of M3. M3 also includes an anticorrosion package, so there’s no need to add anything else to address lubrication or corrosion issues.
To maintain the original properties and comply with Health and Safety regulations, this fuel should be handled and stored in a cool place and always maintained in tightly sealed drums. Property/ Typical Values M1 M3 M5 Test Methods Specific Gravity @ 60F .795 .784 .816 ASTM D 4052 Reid Vapor Pressure 4.60 8.57 7.66 ASTM D 323 Color Clear Clear Clear
Since M3 is not pure methanol, it won’t pass a water test. But where permitted, it will substantially improve performance in 60-70% of all applications, requiring no jetting or timing changes—just pour it in and get up to 5% more Hp. However, not every vehicle will run quicker with M3. For example, in applications that typically run very rich, M3’s improved vaporization will lead to less volumetric efficiency, such that the car will run faster MPH, but stumble at the launch. In most of these instances, jetting changes will reverse that effect. In carbureted systems, smaller squirters and less aggressive pump cams will be required, while injection systems will require leaning out the idle system (not the main system). For customers who want more power but prefer not to deal with these adjustments, M5 will be the best option.
M5TM – M5 is simply the best performing methanol on the market. With its upgraded combustion additives, M5 will make more power than M3, while offering the same or better protection against detonation. Like M3, M5 offers a wider range for tuning, as reflected by the fact that the bracket racers who have helped us in testing have experienced no problems with tuning or tuning consistency. M5 also reduces noxious methanol fumes, although not as well as M3. That means that while M5 is the best choice for making the most power in unrestricted applications, M3 will still be the best option for some venues, notably enclosed stadiums. M5 is not pure methanol and won’t pass a water test.
M2TM Upper Lube – Designed for use in methanol-powered engines, M2 protects valves, guides, cylinder walls, fuel pumps and aluminum fuel systems, and extends pump life. Using electrochemical plating technology—a big improvement over just using oil—M2 leaves a thin film of lubrication to protect against corrosion between races. Recommended for use with M1 or any other standard methanol, while it’s not required with M3 or M5 due to their lubrication additives.
Technical questions on applications and tuning can be referred to VP’s Technical Department at 812-878-2026 or [Email]tech@vpracingfuels.com.[/Email] VP’s methanol products can be ordered via any of VP’s regional distribution centers, contact information for which is available on VP’s website at vpracingfuels.com. VP’s methanol products are available in 5-gallon pails and 54-gallon drums, as well as bulk.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: BobR]
#1273844
07/26/12 02:01 PM
07/26/12 02:01 PM
MRMOPAR622
Sweet Home Alabama
Web site says start 15 percent richer! Greg that is back to what I was thinking at the start,but a man on YB told me to go 6-8 sizes bigger on the return pill,which would lean it out.Maybe he meant by bigger putting more fuel in it,which would be going smaller on the pill(jet)in the return line. I hope my dyno guy knows a little more than me and between the 2 of us we can get it right.Its like Bob said not that much higher and I have seen people cars at the track be .50 faster in the 1/8 mile after switching to it.In my case I cannot afford to have to T&T 4-5 times to get it right.It just cost so much now days just to get to the track and if you don't make a little $$$ it becomes almost impossible.
[Re: BobR]
#1273845
07/26/12 03:45 PM
07/26/12 03:45 PM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
We are using M5 in our Outlaw car. Yes you use more fuel but we started with M5 and have no basis for comparison. We use electronic fuel injection/BS3 on the hemi. The extra power is a plus but besides that it also has lube already in it and it really doesn't cost much more than M1. It is nasty to the eyes...FOR SURE.
Any chance it has a touch of nitro?
[Re: cudarex]
#1273846
07/26/12 04:11 PM
07/26/12 04:11 PM
Posts: 8,165 Left Coast
BobR
Left Coast
It has nitro paraffins and will fail a fuel check if they are checking for nitro.
[Re: greendart408]
#1273848
07/27/12 11:58 AM
07/27/12 11:58 AM
MRMOPAR622
Sweet Home Alabama
I talked with the Tech @ VP(Super Nice Guy)who was very helpful.He said to go down about 5-8 sizes on the return pill to richen it up for the M5. I run #40 nozzels(he said no need to change them)with a #88 pill(jet)in the return line he said go down to a #80 pill unless I thought I was on the rich side and if that was the case only go down to a #83. Maybe between all of us sharing info. we can get the M5 dialed in and working at the start!
[Re: MRMOPAR622]
#1273849
07/31/12 12:46 PM
07/31/12 12:46 PM
MRMOPAR622
Sweet Home Alabama
Web site says start 15 percent richer! One tester found the sweet spot for his motor was between 8 and 15 percent more M5 than regular alky. M5 also likes to idle leaner than straight methanol. When you hear the exhaust making funny noises when leaning out, they said to go back 1/4 to 1/3 turn on the barrel valve for best results. I am going to try some next time out.
-------------------- GREG Hi Greg,did you get a chance to test some M5 this weekend,or stay at home out of the heat like most the rest of us did?
[Re: greendart408]
#1273851
07/31/12 03:36 PM
07/31/12 03:36 PM
MRMOPAR622
Sweet Home Alabama
I tried some M3 when it 1st come out along with a new engine that I did not have a handle on the tune up at the time,it made no different.But they say the M3 is for the carbs. & M5 for injection,and to be honest I do not think I riched it up enough.I was getting my info from a chevy guy,and Mopars seem to like more fuel than a chevy.This time on the dyno now that I know its richer (almost listen to some more wrong advice or misunderstood what he was saying)if I do not see anything going 8 steps richer(meaning use a smaller jet in the return to richen)I will try 12-16 steps richer. "Good Luck" Guys trying the M5,hopefully in a few weeks I will have some dyno results to share on switching from M1-M5. PS It might not be a bad idea to try a small timing change,to get better results.
[Re: MRMOPAR622]
#1273852
08/13/12 10:25 AM
08/13/12 10:25 AM
Posts: 1,073 oregon
greendart408
oregon
Thought I would update my findings on m5 methanol, Just got back from a weekend at the track. I ran my car on the friday night test and tune in 90 plus degree heat, no prep on track and Hot. tuned it to a, 1.361 spun 6.135@112.49.650@138.88with regular methanol. came back to pits drained fuel cell and filled with M5 and richened a few steps. First untuned M5 pass in same or worse conditions resulted in, 1.360 spun bad 6.102@113.359.591@139.96. A new best , now I need to find a fuel sponsor as I am ruined with new fuel. This stuff is amazing.
[Re: greendart408]
#1273853
08/13/12 10:55 AM
08/13/12 10:55 AM
Posts: 901 oh
julian2007
oh
watch when you richen it up you dont go too far you will beat the bearings out of it,also I have herd of people breaking blocks.
Run a vacuum gauge and if its loosing vacuum down track it is too rich and you will hurt it.
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
[Re: greendart408]
#1273854
08/15/12 12:25 PM
08/15/12 12:25 PM
BobR
Left Coast
Thought I would update my findings on m5 methanol, Just got back from a weekend at the track. I ran my car on the friday night test and tune in 90 plus degree heat, no prep on track and Hot. tuned it to a, 1.361 spun [Email]6.135@112.4[/Email] [Email]9.650@138.88[/Email] with regular methanol. came back to pits drained fuel cell and filled with M5 and richened a few steps. First untuned M5 pass in same or worse conditions resulted in, 1.360 spun bad [Email]6.102@113.35[/Email] [Email]9.591@139.96.[/Email]
Yes it is but it's hard on fluorosilicone O rings.
[Re: MRMOPAR622]
#1273855
08/16/12 09:58 AM
08/16/12 09:58 AM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
MRMOPAR I got one pass on the car and a failed rocker arm sent needle bearings through my pump and trashed a bunch of stuff, including rod bearings. I'm not going to say whose rocker arms they are, but their initials are JESEL. I do think the car was a bit faster, looking at a poor 60 ft (off by .035) and bucking a 10 mph head wind the car still ran fast for the weather. I do need to go up more on the fuel though,so the results aren't in yet.
[Re: greendart408]
#1273856
08/16/12 04:57 PM
08/16/12 04:57 PM
Posts: 6,314 The Swamp
MegaDart
The Swamp
IMO, I think you need more data. Like on a well prepped track, ABA testing for best results... I'm not trying to rain on your parade but 3x the cost of regular meth for 1mph gain? I wouldn't even consider it.
