Picked up an F body! #1273448
07/25/12 03:25 AM
07/25/12 03:25 AM
S.E. Minnesota
gtsdude Offline OP
gtsdude  Offline OP
S.E. Minnesota
Bought this new hot rod, should make a good bracket car. Has a 72 340 and 8 3/4 rear. Not sure what gears are but it is limited slip. Really solid body, came from North Carolina. Been parked for 5 years.
Re: Picked up an F body! [Re: gtsdude] #1273449
07/25/12 06:33 AM
07/25/12 06:33 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I always liked mine. Had it since 77. The only problem is they're kind of heavy compared to an A- Body. Mine has gone 1.53 60ft@3875lbs with the stock rear springs stiffened with a couple of leaves. good luck and enjoy it.
Doug
Re: Picked up an F body! [Re: dvw] #1273450
07/25/12 10:54 AM
07/25/12 10:54 AM
Ma
Voluster Offline
Voluster  Offline
Ma
Car seems to be in good shape
The stripes would have to go along with the wheels
Good luck with it
Re: Picked up an F body! [Re: gtsdude] #1273451
07/25/12 11:12 AM
07/25/12 11:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Unbolt the K-member with the transverse T-bars and
put some struts on the front to lighten up the front
end... I was in on the design of that front end and
built MANY of them but its heavy... great if you want
to build a street rod but not very good for drag racing
Re: Picked up an F body! [Re: gtsdude] #1273452
07/25/12 03:26 PM
07/25/12 03:26 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Right on! Those reverse offset wheels are SAWEET!
What are the plans for that beauty?
-Kenny
Re: Picked up an F body! [Re: StrokerAspen] #1273453
07/27/12 09:22 PM
07/27/12 09:22 PM
S.E. Minnesota
gtsdude Offline OP
gtsdude  Offline OP
S.E. Minnesota
Plans are to run it like it is for the summer, my 17 y/o son is going to drive it a little. He made his first pass 3 weeks ago in my 06 charger and he is hooked. He just needs to show some interest in working on it.
Re: Picked up an F body! [Re: gtsdude] #1273454
07/28/12 01:49 PM
07/28/12 01:49 PM
Fort Worth, TX
Dago Red Offline
Dago Red  Offline
Fort Worth, TX
Scott, welcome to Mopar's version of the crazy uncle in the basement!
F's make great bracket cars. Turns out they make good Stockers and S/S race cars too.
Get ready for the following:
1-"What year is your Nova?"
(snuck into Super Chevy with one, told 'em it was a "Canadian Nova")
2-"Those things are tanks!"
(my all steel wagon, factory glass weighs 3180# w/o driver)
3-"Worst car EVER built"
(right....and 35 years later, they're STILL around)
I always listen to what Raff says, he's a smart guy, but, in the interest of cost savings ya might "get by" with the stock front end.
However ,the rubber doohickeys holding it to the frame will hafta go.
I believe somebody sells solid replacements
If You Can't Be Good, At Least Be Colorful
