Re: M/T ET Street Radials?
[Re: quickd100]
#1271905
07/22/12 02:56 PM
07/22/12 02:56 PM
Triple Threat
Renton Washington
18 everywhere I like a smooth ride LOL We run my dads 315/60's at 14-16# when racing.
[Re: Triple Threat]
#1271906
07/22/12 05:05 PM
07/22/12 05:05 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: quickd100]
#1271908
07/22/12 07:15 PM
07/22/12 07:15 PM
Posts: 4,041 michigan woods
imfixinmopars426
michigan woods
I've got a dumb question. I've got a new set of P315/60R-15's what air pressure is everyone running on the street with these things? Dave
is it really going to matter? from the sounds of the monster turning them,they dont have a chance..lol
[Re: imfixinmopars426]
#1271909
07/22/12 09:53 PM
07/22/12 09:53 PM
Posts: 6,295 U.S.
moparniac
U.S.
I run 15 but think I'm gonna try a little higher next time.
Mopar Performance
[Re: Jeepmon]
#1271915
07/23/12 12:20 PM
07/23/12 12:20 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I run about 25 psi on the street, then lower them down to 15-ish at the track
Radials at 15?? they don't "cup" I was told not to go under 18 w/ the radials. I even tried 16 once and they didn't hook at all. I've had both ethe MT radials and the Hoosiers ran both at 30 on the street and 18-19 at the track.
[Re: quickd100]
#1271916
07/23/12 12:43 PM
07/23/12 12:43 PM
Posts: 951 Alliance, Ohio
Valiant_Showoff
Alliance, Ohio
Well I tryed 26#'s, stopped out on my semi-private test track. I dropped it in low, nailed it, shifted to 2nd and had to get out of it or I'd have waded it up in the ditch. I'll try 18lbs. next go around, the tires still seem like they're too hard yet. It probably won't make much difference, this truck motor just makes a pile of tire shreading torque. Dave
My ET Radials never hook on the street. And they don't hook at the track without a healthy burnout first. Many folks indicate that very little burnout is needed, but I have found the burnout to be critical to their hook. Fry them first and then try your launch test. You should see a noticeable difference.
