Re: new Moparts fastest car list, post yours!
[Re: Bubba]
#12714
09/23/04 10:30 AM
09/23/04 10:30 AM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
will someone stick mine where it belongs... b3422w5 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Bubba]
#12715
09/23/04 10:55 AM
09/23/04 10:55 AM
Posts: 1,664 North Sweden
RT540
North Sweden
Done ---7 second zone ---572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone ---The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone ---Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 ---10 second zone ---Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.84@124.4 ---11 second zone --- Bubba '80 Mirada, 440 , 11.11 & 120.32, 1.58 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver mark gates e.t.:11.404 speed: 120.887 3765# 1.569 sixty 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4 Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446 JamesTait, '70 RR 440 4-spd 3.91 12.4 @ 114.04 (1.9 60')
[Re: Bubba]
#12716
09/23/04 03:25 PM
09/23/04 03:25 PM
Posts: 441 Seaside,Ca.
TC67CUDA
Seaside,Ca.
7 second zone --- 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor ---10 second zone --- Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.84@124.4 ---11 second zone --- Bubba '80 Mirada, 440 , 11.11 & 120.32, 1.58 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver mark gates e.t.:11.404 speed: 120.887 3765# 1.569 sixty 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4 Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446 JamesTait, '70 RR 440 4-spd 3.91 12.4 @ 114.04 (1.9 60') ---13 second zone ---
[Re: RT540]
#12717
09/23/04 03:29 PM
09/23/04 03:29 PM
TC67CUDA
Seaside,Ca.
One more time ---7 second zone ---572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone ---The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone ---Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 ---10 second zone ---Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.84@124.4 ---11 second zone --- Bubba '80 Mirada, 440 , 11.11 & 120.32, 1.58 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver mark gates e.t.:11.404 speed: 120.887 3765# 1.569 sixty 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4 Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446 JamesTait, '70 RR 440 4-spd 3.91 12.4 @ 114.04 (1.9 60')
[Re: TC67CUDA]
#12718
09/24/04 01:37 PM
09/24/04 01:37 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
---7 second zone --- 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 ---10 second zone --- Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.84@124.4 ---11 second zone --- Bubba '80 Mirada, 440 , 11.11 & 120.32, 1.58 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver mark gates e.t.:11.404 speed: 120.887 3765# 1.569 sixty 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4 Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446 JamesTait, '70 RR 440 4-spd 3.91 12.4 @ 114.04 (1.9 60') OUTLAWD, 12.75 @ 107.5, 1.89 60', 360/727/3.23,street tires
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#12720
09/25/04 04:49 AM
09/25/04 04:49 AM
Posts: 6,355 Cambridge Vt.
mark_gates
Cambridge Vt.
---7 second zone --- 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 ---10 second zone --- Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.84@124.4 ---11 second zone --- Bubba '80 Mirada, 440 , 11.11 & 120.32, 1.58 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver mark gates e.t.:11.404 speed: 120.887 1.569 sixty 451/727/3.91 #3765 AMC Pacer 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4 Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446 JamesTait, '70 RR 440 4-spd 3.91 12.4 @ 114.04 (1.9 60') OUTLAWD, 12.75 @ 107.5, 1.89 60', 360/727/3.23,street tires
[Re: mark_gates]
#12721
09/26/04 08:37 AM
09/26/04 08:37 AM
Posts: 1,629 pa
572charger
pa
hey some one stick me on there !! 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car !
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: 572charger]
#12722
09/26/04 09:40 AM
09/26/04 09:40 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
Post deleted by Defbob
[Re: Plumb Wired]
#12723
09/26/04 10:29 AM
09/26/04 10:29 AM
#12725
09/26/04 07:55 PM
09/26/04 07:55 PM
mark_gates
Cambridge Vt.
Time to bump me up a couple spots... ---7 second zone --- hemifred single turbo road runner 7.21 @ 193 mph 1.11 60' 1/8th 4.56 @ 156 mph 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 hemifred SOX&MARTIN HEMI DUSTER 8.781 @ 154.16 mph 1.261 60' all motor RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 ---10 second zone --- Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.84@124.4 ---11 second zone --- Bubba '80 Mirada, 440 , 11.11 & 120.32, 1.58 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned mark gates AMC Pacer 11.33 @ 120.087 1.55 60' #3765 iron head 451/727/3.91 LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4 Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446 JamesTait, '70 RR 440 4-spd 3.91 12.4 @ 114.04 (1.9 60') OUTLAWD, 12.75 @ 107.5, 1.89 60', 360/727/3.23,street tires
[Re: mark_gates]
#12727
09/27/04 10:49 AM
09/27/04 10:49 AM
Posts: 6,353 Aurora, Oh.
max_maniac
Aurora, Oh.
---7 second zone --- hemifred single turbo road runner 7.21 @ 193 mph 1.11 60' 1/8th 4.56 @ 156 mph 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 hemifred SOX&MARTIN HEMI DUSTER 8.781 @ 154.16 mph 1.261 60' all motor RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 ---10 second zone --- Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.84@124.4 Max-Maniac 64 Dodge Max Wedge. 10.85 @ 121.2 1.50 60' ---11 second zone --- Bubba '80 Mirada, 440 , 11.11 & 120.32, 1.58 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned mark gates AMC Pacer 11.33 @ 120.087 1.55 60' #3765 iron head 451/727/3.91 LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4 Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446 JamesTait, '70 RR 440 4-spd 3.91 12.4 @ 114.04 (1.9 60') OUTLAWD, 12.75 @ 107.5, 1.89 60', 360/727/3.23,street tires
[Re: max_maniac]
#12728
10/02/04 03:28 PM
10/02/04 03:28 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
---7 second zone --- hemifred single turbo road runner 7.21 @ 193 mph 1.11 60' 1/8th 4.56 @ 156 mph 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 hemifred SOX&MARTIN HEMI DUSTER 8.781 @ 154.16 mph 1.261 60' all motor RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 ---10 second zone --- Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.84@124.4 Max-Maniac 64 Dodge Max Wedge. 10.85 @ 121.2 1.50 60' ---11 second zone --- Bubba '80 Mirada, 440 , 11.11 & 120.32, 1.58 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned mark gates AMC Pacer 11.33 @ 120.087 1.55 60' #3765 iron head 451/727/3.91 LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4 Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446 JamesTait, '70 RR 440 4-spd 3.91 12.4 @ 114.04 (1.9 60') OUTLAWD, 12.75 @ 107.5, 1.89 60', 360/727/3.23,street tires 67Charger, 12.854 @ 105.48, '67 Charger, 440/727 (original), 4.10's 3800#
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: mark_gates]
#12729
10/03/04 06:25 AM
10/03/04 06:25 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142
Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH
---10 second zon1.350 60FT 9.972 E.T 131.56 MPH
6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52
[Re: gregsdart]
#12730
10/03/04 11:59 AM
10/03/04 11:59 AM
67Charger
Erda, UT
---7 second zone --- 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bigcube '69 Dart 9.91et 137 mph, 2950lbs, all motor b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH ---10 second zon1.350 60FT 9.972 E.T 131.56 MPH Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.84@124.4 ---11 second zone --- Bubba '80 Mirada, 440 , 11.11 & 120.32, 1.58 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver mark gates e.t.:11.404 speed: 120.887 1.569 sixty 451/727/3.91 #3765 AMC Pacer 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires 6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52 topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4 Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446 JamesTait, '70 RR 440 4-spd 3.91 12.4 @ 114.04 (1.9 60') OUTLAWD, 12.75 @ 107.5, 1.89 60', 360/727/3.23,street tires 67Charger, 12.854 @ 105.48, '67 Charger, 440/727 (original), 4.10's 3800#
[Re: gregsdart]
#12731
10/03/04 08:49 PM
10/03/04 08:49 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
---7 second zone ---572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone ---The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone ---Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH ---10 second zone--- Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.84@124.4 ---11 second zone ---Bubba '80 Mirada, 440 , 11.11 & 120.32, 1.58 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver mark gates e.t.:11.404 speed: 120.887 1.569 sixty 451/727/3.91 #3765 AMC Pacer 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires 6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52 topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4 Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446 JamesTait, '70 RR 440 4-spd 3.91 12.4 @ 114.04 (1.9 60') OUTLAWD, 12.75 @ 107.5, 1.89 60', 360/727/3.23,street tires A new best
[Re: mark_gates]
#12733
10/06/04 01:38 PM
10/06/04 01:38 PM
85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off)
Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer
