Page 8 of 12 1 2 6 7 8 9 10 11 12
Re: vibration update on the cuda [Re: Quicktree] #127004
11/23/08 10:58 AM
11/23/08 10:58 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
I had a customers duster that had a vibration problem years ago. I ended up changing all the simple stuff first. changed the tail shaft bushing, output shaft, yokes, ujoints, had the drive shaft balanced. nothing helped. I finally put one of my transmissions in it and the problem was gone. I tore down the tranyy and couldn't see anything wrong
I hear ya there and tried all that too lol, the only left from my other tranny is the valve body, everything else is different, a problem like this makes me wanna sell the car lol
Re: vibration update on the cuda [Re: cudadan] #127005
11/23/08 11:11 AM
11/23/08 11:11 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Have you considered trying a factory damper that is attached to the tail housing?
Re: vibration update on the cuda [Re: PC-CHARGER] #127006
11/23/08 11:50 AM
11/23/08 11:50 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
, it wouldn't hurt to try something like that, but the only thing is something has cause this, and im affraid to race incase something lets go on the track
Re: vibration update on the cuda [Re: cudadan] #127007
11/25/08 07:43 AM
11/25/08 07:43 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
and it still does this vibration, only in 3rd gear even after another trans
Re: vibration update on the cuda [Re: cudadan] #127008
11/25/08 09:05 AM
11/25/08 09:05 AM
, PA
sleepyhead416 Offline
, PA
Dan I would be looken for a set of S/S springs. I've had them on my AAR & my Hemi R/T neither car sat high I dont like that look either the front spring bracket has holes to adjust height. Are your rear springs 24 years old ????? I still think it's a pinion angle problem thats why your u-joint don't last.
Re: vibration update on the cuda [Re: cudadan] #127009
11/25/08 03:51 PM
11/25/08 03:51 PM
Red Bluff, CA
W
WilliamHall Offline
super gas
WilliamHall  Offline
super gas
W
Red Bluff, CA
I am guessing its the transmission. To me its simple, you changed the transmission and it started happening.
Re: vibration update on the cuda [Re: WilliamHall] #127010
11/25/08 07:36 PM
11/25/08 07:36 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
but i pulled the trans pull all NEW internals in it and tail housing, the only thing that is still the same is the valve body and the housing itself. maybe if the housing has a lil crack that isnt noticable
Post deleted by Defbob [Re: cudadan] #127011
11/25/08 08:48 PM
11/25/08 08:48 PM
Re: vibration update on the cuda #127012
11/25/08 09:08 PM
11/25/08 09:08 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
LMAO its alomst there Fred
Re: vibration update on the cuda [Re: cudadan] #127013
11/26/08 12:06 AM
11/26/08 12:06 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Try a whole new trans.
There must be something off in that case. Maybe just a few thousandths or something, but something is wrong.
Or the rear end housing is bent.
Post deleted by Defbob [Re: SomeCarGuy] #127014
11/26/08 12:14 AM
11/26/08 12:14 AM
Re: vibration update on the cuda #127015
11/26/08 05:36 AM
11/26/08 05:36 AM
Airville Pa.
boomer Offline
boomer  Offline
Airville Pa.
Posted 2 months ago on this thread to check rear end housing. Everything else has either been checked or replaced EXCEPT for the housing....... Change it.
Re: vibration update on the cuda [Re: SomeCarGuy] #127016
11/26/08 05:38 AM
11/26/08 05:38 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Re: vibration update on the cuda [Re: boomer] #127017
11/26/08 07:54 AM
11/26/08 07:54 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
i tried running it in 3rd gear WITHOUT the axles in the rear, so the only thing spinning is the gears
Re: vibration update on the cuda [Re: cudadan] #127018
11/26/08 12:43 PM
11/26/08 12:43 PM
Red Bluff, CA
W
WilliamHall Offline
super gas
WilliamHall  Offline
super gas
W
Red Bluff, CA
I would just find it too concidental that this vibration would happen from something in the rear as soon as he changed the transmission. Its a possibility but I doubt it. Borrowing a known good transmission would be my first choice in this hard to solve problem.
Re: vibration update on the cuda [Re: WilliamHall] #127019
11/26/08 12:48 PM
11/26/08 12:48 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
thats what im trying to do now, just they are getting harder and harder to find. any locl\al guys have one i can borrow? LMAO
Re: vibration update on the cuda [Re: Quicktree] #127020
11/26/08 01:28 PM
11/26/08 01:28 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I need your address so I can send you a five dollar bill. That should cover the expences.
Getting old just means you were smarter than some and luckier than others.
Re: vibration update on the cuda [Re: dannysbee] #127021
11/26/08 05:05 PM
11/26/08 05:05 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
well i located a trans and im picking it up this friday so by saturday morning i know if its the transmission, dam n i hope so
Re: vibration update on the cuda [Re: cudadan] #127022
11/26/08 05:27 PM
11/26/08 05:27 PM
nc
cold85 Offline
cold85  Offline
nc
I am watching this thread I have the same problem with my charger I have changed real axles new wheels new 5-speed trans with new alum driveshaft and I still have a vibration.
Re: vibration update on the cuda [Re: cudadan] #127023
11/26/08 06:13 PM
11/26/08 06:13 PM
PA USA
flatiron Offline
flatiron  Offline
PA USA
I know exactly what your going thru. I had almost the same post on here this past summer for my 67 Coronet. Same symptons tried alot of the easier stuff. Nothing I did made a change. Never got it on the strip like I planned now it's in storage till next spring and I get to spend the winter scratching my head about it. Looking forward to seeing your out come may be get me pointed in the right direction.
