Re: vibration update on the cuda
[Re: Quicktree]
#127004
11/23/08 11:58 AM
11/23/08 11:58 AM
Posts: 2,617 Stratford nj
cudadan
Stratford nj
I had a customers duster that had a vibration problem years ago. I ended up changing all the simple stuff first. changed the tail shaft bushing, output shaft, yokes, ujoints, had the drive shaft balanced. nothing helped. I finally put one of my transmissions in it and the problem was gone. I tore down the tranyy and couldn't see anything wrong
I hear ya there and tried all that too lol, the only left from my other tranny is the valve body, everything else is different, a problem like this makes me wanna sell the car lol
[Re: PC-CHARGER]
#127006
11/23/08 12:50 PM
11/23/08 12:50 PM
cudadan
Stratford nj
Have you considered trying a factory damper that is attached to the tail housing?
, it wouldn't hurt to try something like that, but the only thing is something has cause this, and im affraid to race incase something lets go on the track
[Re: WilliamHall]
#127010
11/25/08 08:36 PM
11/25/08 08:36 PM
cudadan
Stratford nj
I am guessing its the transmission. To me its simple, you changed the transmission and it started happening.
but i pulled the trans pull all NEW internals in it and tail housing, the only thing that is still the same is the valve body and the housing itself. maybe if the housing has a lil crack that isnt noticable
Post deleted by Defbob
[Re: cudadan]
#127011
11/25/08 09:48 PM
11/25/08 09:48 PM
#127012
11/25/08 10:08 PM
11/25/08 10:08 PM
cudadan
Stratford nj
LMAO its alomst there Fred
[Re: SomeCarGuy]
#127014
11/26/08 01:14 AM
11/26/08 01:14 AM
[Re: SomeCarGuy]
#127016
11/26/08 06:38 AM
11/26/08 06:38 AM
Quicktree
Try a whole new trans.
There must be something off in that case. Maybe just a few thousandths or something, but something is wrong.
Or the rear end housing is bent.
[Re: boomer]
#127017
11/26/08 08:54 AM
11/26/08 08:54 AM
cudadan
Stratford nj
Posted 2 months ago on this thread to check rear end housing. Everything else has either been checked or replaced EXCEPT for the housing....... Change it.
i tried running it in 3rd gear WITHOUT the axles in the rear, so the only thing spinning is the gears
[Re: cudadan]
#127018
11/26/08 01:43 PM
11/26/08 01:43 PM
Posts: 803 Red Bluff, CA
WilliamHall
super gas
super gas
Red Bluff, CA
I would just find it too concidental that this vibration would happen from something in the rear as soon as he changed the transmission. Its a possibility but I doubt it. Borrowing a known good transmission would be my first choice in this hard to solve problem.
[Re: WilliamHall]
#127019
11/26/08 01:48 PM
11/26/08 01:48 PM
cudadan
Stratford nj
thats what im trying to do now, just they are getting harder and harder to find. any locl\al guys have one i can borrow? LMAO
