Re: vibration update on the cuda
[Re: 70challenger408]
#127026
11/27/08 10:02 AM
11/27/08 10:02 AM
Posts: 2,617 Stratford nj
cudadan
Stratford nj
dan, I posted with the same problem on my challenger this past summer. I have changed every thing from the flex plate back, with the same results as you. The only thing left is the rear diff housing. I was looking for Santa to leave a new Moser housing under the tree this year LMAO. scott
LMAO well if this other trans doesnt do it, i have another housing thats getting powerder coated next week, but i dont really think its the housing if it still has the vibes without the axels in it on the jack stands, still gonna change it anyway, i also measured the wheel base the other day and there was only 1/8" of a difference between sides.
[Re: scatpacktom]
#127028
11/27/08 10:17 AM
11/27/08 10:17 AM
cudadan
Stratford nj
I hope the trans works for you Dan and all your questions get answered.
you and me both, lol thx again to everyone for all there help.
[Re: cudadan]
#127029
11/27/08 11:07 AM
11/27/08 11:07 AM
Posts: 724 PA USA
flatiron
PA USA
i swear im losing sleep over this, i just can't believe how long ive had this problem., just hopefully when i try this other trans it goes away, i need to race LOL
I'm just curious have you ran this car down the strip while this problem's been going on. I'm half scared to drive mine.
[Re: flatiron]
#127030
11/27/08 01:04 PM
11/27/08 01:04 PM
Posts: 210 mass,usa
sickhemi
mass,usa
i think it's the output shaft. any chance you had two bent ones? when you changed the driveshaft did you use the same front yoke or did you use a different one?
1968 gts 355 r3 six speed efi with irs in progress and 1969 convt 440 stage 6 efi 5spd dana
[Re: flatiron]
#127031
11/27/08 10:40 PM
11/27/08 10:40 PM
cudadan
Stratford nj
yeah it its scary at 110mph
[Re: sickhemi]
#127032
11/27/08 10:41 PM
11/27/08 10:41 PM
cudadan
Stratford nj
anything is possible, with all of the driveshafts i've tried they all had there own yoke on them, with the same results
[Re: MoparDonny]
#127036
11/28/08 10:53 PM
11/28/08 10:53 PM
cudadan
Stratford nj
You got that trans in yet, Dan? Ha ha!! JK!!
I hope you figure this out tonight! Good luck. You must be pulling your hair out by now.
Don.
i got it lol, just pulled the trans out of the car, and tomorrow morning the new one goes back in. please please please don't vibrate LOL i'll have an update probably by lunch time
[Re: fullmetaljacket]
#127039
11/29/08 10:41 AM
11/29/08 10:41 AM
cudadan
Stratford nj
well the trans is out, and i pulled the flexplate to get a better look at it and saw that 2 of the torque converter hole were a lil worn, and the other 2 are perfect, would the 2 hole that are perfect keep it all inline? not sure if this is the problem, just went out and bolted the flexplate to the converter kept the bolts loose and i cant turn the flexplate on the converter it fits nice and tight no moverment http://picasaweb.google.com/cudadan360/Flexplate?authkey=WKEd3o52m3Y#
[Re: SomeCarGuy]
#127043
11/29/08 04:01 PM
11/29/08 04:01 PM
cudadan
Stratford nj
Unfing believeable
could'nt have said it better myself, gonna swap the valve bodys now so i know im in 3rd with the manual valve body
