My 541 is 440 source crank and pistons and GRP rods. I will run the 4.5 crank from now on. It's a great combo to build torque.
You need to check the piston that is installed in the picture. J.Rob
" Houston, we have a problem".
RAMM, you guys been down to any DIRT races here this year...last night was a GIANT crowd for Tony Stewart at Brewerton.
RIP Monte Smith
