Re: Big stroker in stock block [Re: FastmOp] #1269932
07/19/12 01:44 PM
07/19/12 01:44 PM
The Great White North
RAMM Offline
RAMM  Offline
My 541 is 440 source crank and pistons and GRP rods. I will run the 4.5 crank from now on. It's a great combo to build torque.
You need to check the piston that is installed in the picture. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Big stroker in stock block [Re: RAMM] #1269933
07/19/12 01:53 PM
07/19/12 01:53 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
" Houston, we have a problem".
RAMM, you guys been down to any DIRT races here this year...last night was a GIANT crowd for Tony Stewart at Brewerton.
RIP Monte Smith
Re: Big stroker in stock block [Re: RAMM] #1269934
07/19/12 01:55 PM
07/19/12 01:55 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Oh yeah, you are right. I just saw that too. I do see he is running the 2.2 small journal
Re: Big stroker in stock block [Re: CompWedgeEngines] #1269935
07/19/12 08:50 PM
07/19/12 08:50 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Tony was here Tuesday at Lernerville. Heard it was great.
Re: Big stroker in stock block [Re: BSB67] #1269936
07/20/12 12:31 AM
07/20/12 12:31 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
yep stuck all eight in it and had the cam in it checking P2V just another night drinking beers
There's only one person to blame! Bud Weiser
Here's a Vid of it. This is one of the first few runs on it, I'm still learning how to drive it I miss the shift cause it yanked good.
http://www.youtube.com/watch?v=BxFq10D5vto&feature=youtube_gdata_player
