Re: vibration update on the cuda
[Re: cudadan]
#126986
10/06/08 06:43 PM
10/06/08 06:43 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
I would take the shaft into a driveshaft shop and have them check it out completly, then I would take it to another one and get a 2nd opinion.
68 Barracuda Formula S 340
Post deleted by Defbob
[Re: Bad340fish]
#126987
10/06/08 06:53 PM
10/06/08 06:53 PM
#126988
10/06/08 07:17 PM
10/06/08 07:17 PM
Posts: 2,617 Stratford nj
cudadan
Stratford nj
Dan Tony Gambardella did my shafts and are fine
whats he charge over there, i've gotten ptices from everyone and the prices are all over the place lol
[Re: DJVCuda]
#126990
10/06/08 08:00 PM
10/06/08 08:00 PM
cudadan
Stratford nj
well you can narrow it down to the drive shaft, rear or springs.
you said you never touched the springs....right?
yeah never touched'em, i put the pinion angle back down to 5.7 down cause thats where its always been. took it out for a ride and i still feel the vibes, even with a new tranny mount too. i'd go with super stock springs but i don't want my car to look likes it ready to go off road cause how high they sit lol, im gonna sand blast my other rear housing and put that in when i get a chance, maybe it could be bent or something.
[Re: cudadan]
#126994
10/08/08 07:30 PM
10/08/08 07:30 PM
[Re: MoparDonny]
#126999
10/11/08 07:11 PM
10/11/08 07:11 PM
cudadan
Stratford nj
How deep is the yoke into the trans and is the rear bushing tight? My driveshaft was 5/8 of an inch or so too short and it vibrated quite bad in the same fashion as you describe.
Don.
the drive shaft that i was first using was in there for 6yrs with no issues, im gonna have one of the driveshafts checked out next week
[Re: rowin4]
#127002
11/23/08 10:11 AM
11/23/08 10:11 AM
cudadan
Stratford nj
one thing i did notice when i put the drive shaft back in there was a bout .010 to .015 side to side play where theu joint sits in the yoke.
I mensioned that you should check the rear yoke for spreading [ twice ] on page three, Why are you changing out the front yoke if its destroying the rear u-joint??? There's probably more slop than that also.You might want to try turning thr rear yoke by hand to see if the pinion goes in and out some , if it does it might be the reason it doesen't vibe in reverse
i did put a new billtet yoke on the rear and the ujoint is a nice tight fit now, as for the rear it self i tried another set of gears, this set is a 3.91 with the same results as the 4.30's and the 3.23's
