Re: vibration update on the cuda
[Re: 493_Scamp]
#126945
09/28/08 07:50 PM
09/28/08 07:50 PM
Posts: 2,617 Stratford nj
cudadan
Stratford nj
I would run it without a shaft.Make a dummy plug out of an old yoke and a plate to keep it from backing out. Run the car at the rpm it vibrates and shift 2-3 a couple times.Remember not to hit park,just shut it off. What happened to the original front drum? Did the bushings and washers look ok? Hows the end play?
thats actaully a good idea there, the front drum was in bad shape and couldnt be reused, end play is all good
[Re: cudadan]
#126946
09/28/08 08:19 PM
09/28/08 08:19 PM
Posts: 885 south louisiana
lowell66dart
south louisiana
If you do pull the tranny bolt the converter back up and check the runout with a dial indicator. I have a B&M flexplate on my 340 that I had to modify to work. Won't buy another one.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
[Re: lowell66dart]
#126947
09/28/08 09:35 PM
09/28/08 09:35 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Just my as every body else has a cure to your problem. You say that you get two runs before the rear joint goes bad? I would think if it was in the trans the front joint would go. I would look at the rear pinion angle , the rear housing is probably sticking straight up. U-joints can take alot of vibes before they wear out. Also look at the rear yoke to see if it's spread out , if it is, it won't center and cause a vibe and even kick out the joint.
[Re: lowell66dart]
#126948
09/28/08 09:41 PM
09/28/08 09:41 PM
cudadan
Stratford nj
but the flex plate was workn before with no issue could it just go bad?
[Re: rowin4]
#126949
09/28/08 09:44 PM
09/28/08 09:44 PM
cudadan
Stratford nj
but the angle was good before this problem started ive changed the angle up abd down a few degree's all still with the same results
[Re: rowin4]
#126951
09/28/08 11:12 PM
09/28/08 11:12 PM
Posts: 1,728 ST clair shores MI
moretoys
ST clair shores MI
Stock trans mount/height??solid/poly mount?? Maybe the rear axle housing bent.any problems sliding the axles in/out?? Posible bent spring/making thrust angle off.rear wheels pointing more 1 way then the other.(dog tracking) Do you buzz the engine to the same rpm in 1st and 2nd?? Switching to 3.23 gears made the vibration come at a higher mph,Then It has to be rpm related A shot in the dark.the fan??? A cracked flywheel will usually make some noises tailshaft bushings ok?? Vibrations can travel.What if the vibration is up front of the shaft,but the rear u-joints go bad because there is no room to move/ more tightly held together. Have you had it on jackstand,and whatched the driveshaft,should be pretty smooth,any osilation. just thinking outloud.
[Re: cudadan]
#126952
09/28/08 11:16 PM
09/28/08 11:16 PM
Posts: 75,152 A Banana Republic near you.
JohnRR
If the flexplate was in before this and was ok it would still be fine, there are no extra weights on it unless you put some extra holes in it for some strange reason.
what happened to the front drum ?
[Re: JohnRR]
#126953
09/29/08 12:32 PM
09/29/08 12:32 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
How are you sintalling teh u joints? Are you seating them against the clips after installing the clips? It's driveshaft. Definately. If you moved it up and fdowna couple degrees (pinion angle) what is is currently set at? You are positive you're measuring it properly?
[Re: moper]
#126954
09/29/08 06:45 PM
09/29/08 06:45 PM
cudadan
Stratford nj
im using a vise to put them in and pushing them up against the clips too. for a few yrs i was running at 5.7 down with no problem, then i moved it up a degree at a time to 2.7 and all still had the same results. im gonna order a brand new yoke just so i can eliminate that
[Re: moretoys]
#126955
09/29/08 07:19 PM
09/29/08 07:19 PM
cudadan
Stratford nj
Stock trans mount/height??solid/poly mount?? Maybe the rear axle housing bent.any problems sliding the axles in/out?? axles go in great Posible bent spring/making thrust angle off.rear wheels pointing more 1 way then the other.(dog tracking) not sure Do you buzz the engine to the same rpm in 1st and 2nd?? yes and no vibes Switching to 3.23 gears made the vibration come at a higher mph,Then It has to be rpm related A shot in the dark.the fan??? electric A cracked flywheel will usually make some noises tailshaft bushings ok?? new tailshaft,housing and bushing Vibrations can travel.What if the vibration is up front of the shaft,but the rear u-joints go bad because there is no room to move/ more tightly held together. Have you had it on jackstand,and whatched the driveshaft,should be pretty smooth,any osilation. just thinking outloud.
, did that the other day, and everything spins so smooth that it doesn't look like its moving
[Re: cudadan]
#126956
09/29/08 07:31 PM
09/29/08 07:31 PM
dartman366
Mt. Vernon, Ohio
I say just give it up and I will come over with my trailer and get it out of your hair and you wont have the problem any more,,,,,,,whatta' ya' think??? J/K hope you sort it out, but i'm outta thought's.
[Re: dartman366]
#126957
09/29/08 07:32 PM
09/29/08 07:32 PM
cudadan
Stratford nj
pleeeeeease come and take it LOL hey and its a real 74 360 cuda too lol
[Re: cudadan]
#126958
09/29/08 07:48 PM
09/29/08 07:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would think your next step would be to take the d-shaft out and put a slip yoke in the trans and mount something to to keep it from falling out. Spin it up to the known problem rpm/speed and see if its still there, that would emininate the d-shaft and rear end if its still there..... or it would say that its a d-shaft or rear end problem if it isnt there
Post deleted by Defbob
[Re: boomer]
#126960
09/29/08 09:12 PM
09/29/08 09:12 PM
