Page 2 of 3 1 2 3
Re: Anyone have problem with Edelbrock heads? [Re: Deepockets] #1266770
07/15/12 11:21 AM
07/15/12 11:21 AM
tboomer Offline
tboomer  Offline
Looks like the Indys are the ones,then. Thanks!!
Re: Anyone have problem with Edelbrock heads? [Re: tboomer] #1266771
07/15/12 11:59 AM
07/15/12 11:59 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
FWIW, I had a mix-n-match of Indy and ARP studs w/ my Stage VI heads: you need to verify the UNthreaded portion of the Indy studs that protrudes through the shaft hold-downs doesn't end up above the top of the hold-downs. If I didn't have some fairly thick shims stacked under my shafts because of rocker geometry "fixes", I would have needed to add extra washers under the nuts that retain the shafts because of this.
Re: Anyone have problem with Edelbrock heads? [Re: mistress] #1266772
07/15/12 12:04 PM
07/15/12 12:04 PM
BradH Offline
BradH  Offline
I sent mine to Dave Hughes and he repaired the head and built a new center rocker tower, it looked better than new...
Was Hughes' repair done by re-welding a new post, or by machining the original post down and adding bolt-down stands like the OP?
Re: Anyone have problem with Edelbrock heads? [Re: BradH] #1266773
07/15/12 12:10 PM
07/15/12 12:10 PM
tboomer Offline
tboomer  Offline
I understand what you are saying,Brad... Did you ever get yours mocked up,yet?
Re: Anyone have problem with Edelbrock heads? [Re: BradH] #1266774
07/15/12 01:00 PM
07/15/12 01:00 PM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
he welded area back up and machined it to original design. i kept the old piece that was broke off.
Re: Anyone have problem with Edelbrock heads? [Re: mistress] #1266775
07/15/12 01:07 PM
07/15/12 01:07 PM
BradH Offline
BradH  Offline
Thanks for the info.
Now I'm all paranoid that I'm going to break the center rocker stands on my Victors once my Challenger's back on the street.
Re: Anyone have problem with Edelbrock heads? [Re: 451Mopar] #1266776
07/15/12 02:22 PM
07/15/12 02:22 PM
BradH Offline
BradH  Offline
... closed pressure is 275#... open... just over 700#... 3/8"x0.089" wall pushrods.
Also wanted to mention that everything I've seen and heard re: pushrods these days is that yours aren't beefy enough for that much spring pressure / RPM / aggressive lobes.
It probably has nothing to do w/ breaking the shaft pedestals, but could definitely have an impact on valve train longevity. I think most engine builders I deal with would be suggesting at least .120" walls in a 3/8" diam. pushrod.
Re: Anyone have problem with Edelbrock heads? [Re: BradH] #1266777
07/15/12 02:23 PM
07/15/12 02:23 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I think part of the problem is the center stand has the least amount of material around the heli-coil, and it does not stand up the the high spring pressures. Stud or longer bolt won't help the problem because the there is nothing to grip onto below the heli-coil. It seems the other stands are OK, because the heli-coil is much deeper into the head (below the oil hole) on the middle stands, and the outer stands, it is located in a thicker cast section also.
I would recommend removing the center heli-coil, and installing a new one deeper in the head below the machined sides of the center stand. When I installed the Time-Sert I drilled 1-1/2" below the machined area and did not run into anything (like a water jacket.)
Here is a pic of the Time-Sert kit. The kit comes with drill, countersink, tap, installation tool, and 10 of the 1/2" long steel inserts. I think the kit was a bit pricy, around $60? The two 3/4" long stainless inserts at the lower right corner is what I used. They are about $1 each.
Re: Anyone have problem with Edelbrock heads? [Re: 451Mopar] #1266778
07/15/12 02:27 PM
07/15/12 02:27 PM
BradH Offline
BradH  Offline
My concerns about breaking those center pedestals increased x 10 after reading through this thread. Sounds like there's some additional work to do before the heads go on the engine. Thanks.
Re: Anyone have problem with Edelbrock heads? [Re: Deepockets] #1266779
07/15/12 02:29 PM
07/15/12 02:29 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Oops, I forgot to mention the three middle bolts were ground to reduce the diameter for oil flow through the T&D rocker shafts. The T&D rocker shaft has very thick walls, ans if you use a bolt or stud that is not reduced in diameter where it goes through the shaft, it will cut off oil flow to the rockers.
Re: Anyone have problem with Edelbrock heads? [Re: BradH] #1266780
07/15/12 02:37 PM
07/15/12 02:37 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
The pushrods seem OK I have not bent one, but they may be flexing? I was thinking of going to the 0.120 wall pushrods.
Since I have the engine out, I am thinking of having deeper valve reliefs put in the pistons, re-balance it, and get a slightly larger cam like I originally planed. I went to a smaller cam when I noticed I would run into P-V clearance problems with the bigger cam.
Re: Anyone have problem with Edelbrock heads? [Re: 451Mopar] #1266781
07/17/12 10:58 AM
07/17/12 10:58 AM
BradH Offline
BradH  Offline
Anyone think that having some additional material welded around the center pedestal would help w/ this issue? Since it was pointed out that it's only been the centers that have broken and the others w/ more "beef" around them haven't, this came to mind...
Re: Anyone have problem with Edelbrock heads? [Re: BradH] #1266782
07/17/12 05:48 PM
07/17/12 05:48 PM
BradH Offline
BradH  Offline
And a dumb question: Are both of the people who've posted having this problem running the Max Wedge version of the Victor head, or just the OP?
I'm curious because I was just looking over Edelbrock's online catalog (http://www.edelbrock.com/zmags/automotive.shtml) and noticed that on page 147 the pictures show the center pedestal being machined noticeably narrower on the MW version than on the standard Victor.
EDIT: Now I'm not sure what the deal is... found some pics of a standard Victor w/ the same narrower center pedestal as the catalog MW Victor shows. Different manufacturing runs, perhaps?
Re: Anyone have problem with Edelbrock heads? [Re: BradH] #1266783
07/17/12 10:41 PM
07/17/12 10:41 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
FWIW the MW Victors I have here show porosity on the center stand. I am going to call Edelbrock tomorrow and ask what to do about it. I think the right thing to do would be moving the helicoil farther down in the hole where there is more meat.
Re: Anyone have problem with Edelbrock heads? [Re: Jeremiah] #1266784
07/18/12 09:44 AM
07/18/12 09:44 AM
BradH Offline
BradH  Offline
... I think the right thing to do would be moving the helicoil farther down in the hole where there is more meat.
After checking over two sets of the standard Victors last night that both have the same narrow center pedestal, I'm of the same opinion that the heli-coil location is the issue.
Is the Time-Sert kit shown above a legit DIY deal, or should I work w/ a local machine shop to ensure this isn't botched up? I've installed plenty of heli-coils before, but this job looks to be a little different since it involves drilling much deeper than the existing heli-coil, etc.
Re: Anyone have problem with Edelbrock heads? [Re: BradH] #1266785
07/18/12 02:01 PM
07/18/12 02:01 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I talked to a technician at Edelbrock and he stated that they have not seen many failures of this type and asked that we collectively send some pictures of the problem area / broken parts so they can inspect them.
I am going to have the missus photograph the center stand on the heads here to show the dark spots in the casting.
If anyone wants to add to the collection please PM me for my email address and make sure to include your contact information (if Edelbrock can contact you, that is).
To the OP : can I send you pics to Edelbrock?
Anybody else have pictures of broken/damaged rocker stands?
Does anyone have pictures of the Procomp rocker stands?
Re: Anyone have problem with Edelbrock heads? [Re: Jeremiah] #1266786
07/18/12 04:49 PM
07/18/12 04:49 PM
BradH Offline
BradH  Offline
I talked to a technician at Edelbrock and he stated that they have not seen many failures of this type...
I noticed you said "many", rather than "any". That tells me they've seen enough to know it's an issue...
Re: Anyone have problem with Edelbrock heads? [Re: BradH] #1266787
07/18/12 06:21 PM
07/18/12 06:21 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Well let's not assume anything. I took it as "failures with this particular product" or maybe he said "any" and I misunderstood. My day time shop is near the airport and they are pretty busy today.
I would like to make sure that Edelbrock is aware of the problem and see if they are interested in giving us their insight on fixing it/warranty. To me this is a defect in craftsmanship.
Brad, does the center stand on your heads have dark marks in the aluminum like my sets do?
Re: Anyone have problem with Edelbrock heads? [Re: Jeremiah] #1266788
07/20/12 12:30 AM
07/20/12 12:30 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Bump for pictures and approval to send them. I'd like to gain some traction on this but if nobody else cares I will move on...
Re: Anyone have problem with Edelbrock heads? [Re: BradH] #1266789
07/20/12 01:37 AM
07/20/12 01:37 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
If your head is not broken, If you could spin the heli-coil down another 1/2" or so, I think it would be OK, but the insert tang may have been broken off at the factory, so you may have to remove the old one before installing another one deeper. The time-sert is nice, but the top has a step in it that you countersink for. It works great if you have broken the stand and milled the surface flat, but with the stock stand, I would not make the hole larger in diameter because the stand is pretty narrow.
The time-sert can be done by hand like a heli-coil, but a drill press will ensure the hole you drill is perpendicular to the deck, and in-line with the other rocker shaft hold down fasteners.
Page 2 of 3 1 2 3
