Page 2 of 3 1 2 3
Re: heat riser passage block off methods [Re: Fury Fan] #1264741
07/13/12 09:47 AM
07/13/12 09:47 AM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
I orderd the valley pan w/o the hole, but recieved with it. It was mislabled at the factory, so I cut a soda can with a pair of scissors, making 4 plugs to sandwich them on each side of the pan.
I held them together with RTV and sealed the perimiters.....works great!
Re: heat riser passage block off methods [Re: dave571] #1264742
07/13/12 11:08 AM
07/13/12 11:08 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
My solution was a aftermarket manifold,and didn't even know. It is a victor340 manifold in my case. Has a built in air gap and no heat riser passages. Works really well on this motor and never boils the fuel. I have driven it in very hot conditions like 110+ degrees and it does great. No way can you leave them open nowadays with the crap gas I'm guessing. I wouldn't be afraid of using old soup cans or something like that.
Re: heat riser passage block off methods [Re: Dan Halen] #1264743
07/13/12 12:03 PM
07/13/12 12:03 PM
scratchnfotraction Offline
I used a alum soda can,it burnt thru in short order. way to thin. may have better results with 2 stacked like that.
cut some from the old vally pan and rtv them in place on the head, then the install the gasket/pan/gasket/intake.
Re: heat riser passage block off methods [Re: scratchnfotraction] #1264744
07/13/12 02:47 PM
07/13/12 02:47 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
i remember a story of Herb Mc Candles melting down old pistons and pouring it into heads to block off heat riser holes.....
Re: heat riser passage block off methods [Re: Joesixpack] #1264745
07/13/12 06:48 PM
07/13/12 06:48 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
people used to do that.
Re: heat riser passage block off methods [Re: scratchnfotraction] #1264746
07/13/12 10:05 PM
07/13/12 10:05 PM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Balled up big wads of aluminum foil and stuffed them down in there. Crude and effective, kind of keeping with these old Mopars' spirit.
I remember someone on this board post about stuffing it with 100 dollor bills along with that alum foil,so it would pay hiim for the rebuilding of the heads.
ask my buddy that is waiting for his 4oo BB heads back from the machine shop after spitting the alum out the header collectors
results will vary.
How does THAT happen? Seriously...
Re: heat riser passage block off methods [Re: Bull1tt] #1264747
07/13/12 10:15 PM
07/13/12 10:15 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Here's a q - what's the effective difference of just wiring the riser valve wide open? Won't exhaust velocity take care of most of it?
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: heat riser passage block off methods [Re: Secret Chimp] #1264748
07/13/12 10:23 PM
07/13/12 10:23 PM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
We're talking about the water crossover in the intake manifold...
Re: heat riser passage block off methods [Re: Bull1tt] #1264749
07/13/12 10:40 PM
07/13/12 10:40 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
No, no we are not
Don't be the exception.
Re: heat riser passage block off methods [Re: Bull1tt] #1264750
07/13/12 10:46 PM
07/13/12 10:46 PM
Uhh, bigblocks have dry intakes...
Re: heat riser passage block off methods *DELETED* [Re: scratchnfotraction] #1264751
07/13/12 11:33 PM
07/13/12 11:33 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
Post deleted by moparts
Re: heat riser passage block off methods [Re: IronWolf] #1264752
07/13/12 11:36 PM
07/13/12 11:36 PM
tboomer Offline
tboomer  Offline
Enjoy your nice vacation...
Re: heat riser passage block off methods [Re: Rapid340] #1264753
07/14/12 12:46 AM
07/14/12 12:46 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Mopar Performance had offered an intake manifold gasket with two thick (.040-.050) shims to block the heat crossover on small blocks.
I never used this kit due the the shims being so thick. What I do is find a large aerosol can and cut my own shims. The ones I have used where about .011 thick. I have done this MANY times and never had a problem.
I used the MP block offs on my 360. Guess where all my oil was going? I pulled the intake and cut a recess in it for the plates. Glued them in with copper RTV. BTW the gasket they sell is a thin POS.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: heat riser passage block off methods [Re: tboomer] #1264754
07/16/12 09:14 AM
07/16/12 09:14 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Thank, you, Mr Mod. We all have differences of opinion on things, but to say stuff like that over a crossover??? What's wrong with that guy???
Re: heat riser passage block off methods [Re: Fury Fan] #1264755
07/16/12 09:24 AM
07/16/12 09:24 AM
got me?
Re: heat riser passage block off methods [Re: Secret Chimp] #1264756
07/16/12 09:27 AM
07/16/12 09:27 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Yes, but at this point, 35+ years later, most of them are probably frozen open already.
There's 2 parts to this system. The crossver between the heads that runs thru the intake (which we are discussing) and then the riser valve that reroutes the passenger-side exhaust thru that passage.
In my experience, having no riser valve still allows a lot of intake heating to occur.
I installed the blocked intake pan on one of my cars once and got a *terrible* resonance around 2000 RPM, couldn't even drive the car more than once. (2.5" X-pipe exhaust)
Re: heat riser passage block off methods [Re: Fury Fan] #1264757
07/16/12 10:47 AM
07/16/12 10:47 AM
a old timer told me that the cross over also acts like a H-pipe to balance the exhast pulse from right bank to left bank with a single exhast. how true that is I dont know?
opinions? would it in fact do that?
Re: heat riser passage block off methods [Re: scratchnfotraction] #1264758
07/16/12 11:30 AM
07/16/12 11:30 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
We can discuss opinions now that Iron Wolf can't hear us.
I've heard somehting like that, perhaps on here. It would stand to reason that an additional passage could change the resonance frequencies.
I don't know what a jumper tube between 2 pipes on a church organ would do, but it will surely do something.
Re: heat riser passage block off methods [Re: Fury Fan] #1264759
07/16/12 01:29 PM
07/16/12 01:29 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
blocking the intake manifold heat cross over on a car with separate dual exhaust pipes, no "h" or "x", will have an effect on exhaust tone. i used to do this on my road runner back in the day. it had a pretty cool lope with a little bit of camshaft.
Re: heat riser passage block off methods [Re: lewtot184] #1264760
07/16/12 02:32 PM
07/16/12 02:32 PM
this has been my results also with my 85 truck/headers/duel glass packs also.
Page 2 of 3 1 2 3
